by NORCAL - 03/19/24 05:11 PM
0 members (), 260 guests, and 19 robots.
#2232 06/28/01 07:22 PM
F
frank Offline OP
in a room with a 3 meter ceiling (9.8 ft)what size ladder do you use?
a 6 ft
b 8 ft
i think that since you must stand no higher than the third rung from the top of a ladder you would go with 8 ft.but i can reach 10 ft easily.does any one know if there is a rule regardng how far you can extened your body above the top of a ladder
#2233 06/28/01 07:58 PM
http://www.osha-slc.gov/OshStd_data/1917_0119.html
Frank;
check out F7, that may be it..
#2234 06/28/01 09:03 PM
F
frank Offline OP
up im bookmarking the site thanks again!
#2235 06/28/01 09:10 PM
Anonymous
Unregistered
#2236 06/28/01 09:29 PM
Anonymous
Unregistered
a 6 ft
b 8 ft
It doesn't matter how far your body extends above the ladder. What matters is that you do not step on the top of (highest point), or on the second from top of the ladders stepping space. You must (by Osha--or Department of labor) stand on the third most step from the top. (It specifies this on the ladder.) good question!
#2237 06/28/01 09:40 PM
On an extension ladder one can climb up, then step one rung down, threading your foot thru so that the one rung is behind your knee, and the next rung lower is held by the top (dorsal) of the foot.
Then lean back and say 'look ma, no hands!'
assuming ma don't work for OSHA.....
#2238 06/29/01 08:18 AM
I believe that the std Sparky's referring to applies more to extension ladders that are used to climb to rooftops, etc. They also should be tied off at the top. (this std was part of a safety meeting held by our safety compliance consultant).
#2239 06/29/01 01:48 PM
I have a 7 foot step ladder that I purchased on sale at home depot. I find it more useful than an 8 footer and fits in the truck better.
#2240 06/29/01 05:32 PM
I got the Davidson 7 footer too and the 18 extension. They're very light, and rated for 225 lbs which is me (140 lbs) and all I want to carry up a ladder!
-Virgil
5 Star Inspections
Member IAEI
