Admin 17
Anyone hiring inspectors?
by sparky66wv. 03/26/17 12:22 PM
Old decora style outlets
by Admin. 03/25/17 11:40 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
fuse rejectors
by HotLine1. 03/24/17 07:53 AM
Another Forum Update
by Admin. 03/22/17 03:04 PM
SE cable question
231,509 Are you busy
166,213 Re: Forum
160,660 Need opinion
1 registered members (sparky66wv), 62 guests, and 12 spiders.
Rate This Thread
#218198 - 02/08/17 05:57 PM Panel and related questions from a new member
HotLine1  Offline
Brick, NJ USA
Relocated here from Photos
member jdscott2005
Hey guys, this is my first post so thanks in advance for your help.
I'm replacing a 100A service panel and it is on a 3ft wall that runs perpendicular to the exterior wall and this wall is lined up with the meter socket. The inspector said I will not need a disconnect if I am within 5 ft and that I should put the SE cable in pipe...
What type of "pipe" should be used for this 2/2/2/4 SE cable? Should I take my box down and make a hole in the side so I have a straight run? I am very close to that 5ft max the way I have it now running to the top of the box. I assume wire length inside the boxes are not counted toward that 5 feet?
Remind me of what size wire and ground rod I will need to add to this system please. The ground from panel to meter box is #4 aluminum
#218199 - 02/08/17 06:09 PM Re: Panel and related questions from a new member [Re: HotLine1]
HotLine1  Offline
Brick, NJ USA
jdscott2005:
I relocated your post here for better exposure.
The trade practice here is that the service feeder from the meter to the MOCP within a panel must be in a straight path; there is no NEC defined distance for unprotected conductors within a structure. Protection of SEU within "pipe" by the local AHJ is for physical protection of the cable. The diameter of the cable prevents maintaining the required depth from the face of the studs. "Pipe" could be EMT, IMC, or RGC to prevent physical damage.
I see from your profile that you are not an electrician, so you may want to find a local licensed electrician to do this job.
#218208 - 02/09/17 02:48 PM Re: Panel and related questions from a new member [Re: HotLine1]
HotLine1  Offline
Brick, NJ USA
So far, 95 views, and not a single comment, or response from the OP.
#218209 - 02/09/17 04:39 PM Re: Panel and related questions from a new member [Re: HotLine1]
gfretwell  Offline
Estero,Fl,usa
One answer is easy. Run a short rigid nipple across that void with a slight down pitch so water can't intrude, punch a hole in the cabinet at the appropriate place and be sure you install a bonding bushing on the end. Then put some duct seal on the outboard end to exclude moisture bugs etc. We don't know how it terminates outside but he will need some kind of bushing there too.
Example of a bonding bushing
#218213 - 02/09/17 08:11 PM Re: Panel and related questions from a new member [Re: HotLine1]
sparky  Offline
2/4 ser would usually indicate a feeder made off a meter/main....~S~
#218221 - 02/11/17 12:34 AM Re: Panel and related questions from a new member [Re: HotLine1]
HotLine1  Offline
Brick, NJ USA
~s~:
Good catch. So it's SER, not SEU, perhaps a main outside. But, the OP says the inspector said no disconnect if he is within 5'.
OK, either way, physical protection is required, and I can't substantiate the "5'" even if it is SER.
Wonder what part of PA??
HappyElectrician
HappyElectrician
Penn USA
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.020s Queries: 15 (0.004s) Memory: 0.7779 MB (Peak: 0.9254 MB) Zlib enabled. Server Time: 2017-03-26 17:06:17 UTC
