Admin 19
Anyone hiring inspectors?
by HotLine1. 03/27/17 08:03 AM
Old decora style outlets
by Admin. 03/25/17 11:40 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
fuse rejectors
by HotLine1. 03/24/17 07:53 AM
Another Forum Update
by Admin. 03/22/17 03:04 PM
SE cable question
231,626 Are you busy
166,455 Re: Forum
160,717 Need opinion
0 registered members (), 68 guests, and 11 spiders.
Rate This Thread
#217480 - 08/13/16 11:59 AM How Do You Install Drywall?
bostonplaster  Offline
Worcester MA
Begin by hanging the 1/2 finished drywall, wallboard, blueboard, sheetrock, or plasterboard on the walls and ceilings.
Some cities may only have 5/8 or double 5/8 boards for the ceiling. If there are any apartments above, you must screw the plasterboard on the ceiling with at least 5 to 6 screws in each strip.
Only 4 to 5 screws per strip are necessary for the walls. Hang the drywall or plasterboard on the ceiling first, and then the walls after. That will make plastering over the cracks on angles easier.
When hanging the drywall or plasterboard on the walls, be sure to cut the whole drywall over the doors and windows. Using small pieces can cause cracks in the future.
Tape the drywall or plasterboard joints starting with the flat parts of the board. Then place the two pieces together and tape them at an angle.
cheers
Building Codes & Related References
#217482 - 08/13/16 06:46 PM Re: How Do You Install Drywall? [Re: bostonplaster]
HotLine1  Offline
Brick, NJ USA
OK, Thanks for that I guess. I always used to sub out all drywall/plaster work as my crew and myself are electricians.
The same with trenching/excavating
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.012s Queries: 15 (0.002s) Memory: 0.7438 MB (Peak: 0.8603 MB) Zlib enabled. Server Time: 2017-03-28 06:12:28 UTC
