Topic Options
Rate This Topic
#217480 - 08/13/16 08:59 AM How Do You Install Drywall?
bostonplaster Offline
Loc: Worcester MA
Begin by hanging the 1/2 finished drywall, wallboard, blueboard, sheetrock, or plasterboard on the walls and ceilings.
Some cities may only have 5/8 or double 5/8 boards for the ceiling. If there are any apartments above, you must screw the plasterboard on the ceiling with at least 5 to 6 screws in each strip.
Only 4 to 5 screws per strip are necessary for the walls. Hang the drywall or plasterboard on the ceiling first, and then the walls after. That will make plastering over the cracks on angles easier.
When hanging the drywall or plasterboard on the walls, be sure to cut the whole drywall over the doors and windows. Using small pieces can cause cracks in the future.
Tape the drywall or plasterboard joints starting with the flat parts of the board. Then place the two pieces together and tape them at an angle.
cheers
_________________________
Boston Plastering Contractor
Top
Building Codes & Related References
#217482 - 08/13/16 03:46 PM Re: How Do You Install Drywall? [Re: bostonplaster]
HotLine1 Offline
Loc: Brick, NJ USA
OK, Thanks for that I guess. I always used to sub out all drywall/plaster work as my crew and myself are electricians.
The same with trenching/excavating
Top
SE cable question
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Who's Online
0 registered (), 81 Guests and 7 Spiders online.
SE cable question
Top Posters (30 Days)
Admin 47
HotLine1 43
gfretwell 19
Ruben Rocha 12
Trumpy 9
Newest Members
KrmtFrg, Stack, Scotto, Freecrowder, clee512
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
