Admin 19
fuse rejectors
by NORCAL. 03/29/17 01:44 AM
Old decora style outlets
by NORCAL. 03/29/17 01:41 AM
NFPA stuff
by gfretwell. 03/28/17 08:08 PM
Anyone hiring inspectors?
by HotLine1. 03/27/17 08:03 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
SE cable question
231,899 Are you busy
166,776 Re: Forum
160,888 Need opinion
1 registered members (bigrockk), 71 guests, and 13 spiders.
Rate This Thread
#217430 - 07/29/16 04:25 PM Lithonia OLWP LED rapid cycling fix?
sparkyinak  Offline
Alaska
Interesting service call. Customer recently had two OLCP LED fixtures installed to replace older door lights. I have not looked into this yet. As it started to get dark, the light comes on, however reflective light from the awning cuts the light out until it gets darker and all is good.
By design of the fixture where the wiring is all in the bottom of the light not, center or top. The photo eye sits higher on the wall since the photo eye is on top. I've seen the guts of when where it appears that the photo eye is integral to the LED module so I'm not sure if it is even adjustable.
Unlike most photo eyes, this one is really responsive as in like 1 or 2 seconds. The only way I can really test it is be there at twilight and being in Alaska, that like 9 or 10 at night. It will be "fun" to say the least to chase after.
I'm going try to some how "shield" the eye internally however thy may just cause the cycling to start ever earlier. I have only limited time to address the issue. Any one ran into this and found a fix?
#217431 - 07/29/16 05:45 PM Re: Lithonia OLWP LED rapid cycling fix? [Re: sparkyinak]
geoff in UK  Offline
UK
If the photo sensor and the light source are combined, AND there is no sensitivity adjustment, AND the reflectivity causes cycling, then the fitting simply isn't suited to the location.
You have two options, short of replacement. Partially masking or shielding the sensor, or bypassing it and locating a photo-switch elsewhere.
MarkC10
MarkC10
CA, Inland Empire
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.009s Queries: 15 (0.002s) Memory: 0.7428 MB (Peak: 0.8583 MB) Zlib enabled. Server Time: 2017-03-30 22:37:38 UTC
