If I understand you correctly, you are talking about powering up a gymnasium full of PCs. If that is the case, I would suggest placing the three panels in three different corners of the space. That way you avoid a river of extension cords all coming to one location. If you are also using cabled network connections, same suggestion, spread them out to all corners.
If you can, find a local company that does temporary shows like fairs and conventions or a theater and movie equipment rental business and go see how they set up temporary power distribution.
The previous suggestion about placing the panels on movable stands that also double as cable storage is a good idea.
Alternatively, install large power receptacles at the three locations, put a mating plug on a cord that connects to the 200 Amp panel. Now the power panels and associated cables can be rolled up and stored all together.
