Admin 19
Anyone hiring inspectors?
by HotLine1. 03/27/17 08:03 AM
Old decora style outlets
by Admin. 03/25/17 11:40 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
fuse rejectors
by HotLine1. 03/24/17 07:53 AM
Another Forum Update
by Admin. 03/22/17 03:04 PM
SE cable question
231,643 Are you busy
166,541 Re: Forum
160,728 Need opinion
0 registered members (), 81 guests, and 9 spiders.
Rate This Thread
#216681 - 01/22/16 07:05 PM Designing for Power Outages
renosteinke  Offline
Blue Collar Country
As I was setting up my generator this morning, one thing became apparent: I had no easy way to power my alarm, cameras, phone, and computers, short of putting the entire house on the generator.
So, I wonder .... is it a good idea to have a separate circuit, hopping from room to room, providing power to receptacles dedicated to these uses? One could even make this a circuit separate from the usual house wiring, powered only when the generator is in use. Power failure? Just move the plugs.
I almost think I have seen this arrangement in medical facilities- an "emergency" receptacle right next to the 'ordinary' receptacle.
I rather like this arrangement, as it makes the generator network completely separate from the utility-powered network ... no need for transfer switches, no chance of backfeed issues. While the NEC seems to assume transfer switching, I don't think a parallel network is forbidden.
#216682 - 01/22/16 08:48 PM Re: Designing for Power Outages [Re: renosteinke]
LarryC  Offline
Winchester, NH, US
For "down the road" applications, perhaps a dedicated small panel feeding all of the generator powered circuits could be installed. If you decide to install a transfer switch later, some of the wiring is already installed. You would just have to move other dedicated circuits later. It would allow you to run the 240 V output of the generator and give you more power available for the larger loads during an extended outage.
#216685 - 01/22/16 10:45 PM Re: Designing for Power Outages [Re: renosteinke]
HotLine1  Online Content
Brick, NJ USA
Reno:
An inlet, backfed cb, and an interlock kit gets the gen power into your panel. You have to select the branch cbs you want to power up, Works fine for me, and a lot of others, and it's legal.
#216686 - 01/22/16 10:51 PM Re: Designing for Power Outages [Re: renosteinke]
Brick, NJ USA
Reno:
Yes, there are multiple sources in some medical facilities. The "emergency", red HG duplex, and matching plate are from the gen.
#216691 - 01/23/16 03:42 AM Re: Designing for Power Outages [Re: renosteinke]
gfretwell  Offline
Estero,Fl,usa
I have a back feed inlet and an interlock kit here. I am really not that prepared tho. I do have a good panel directory but I have not really gone through and mapped the breakers I would want to have on and the normal load on them. Best case would actually be a load rating on each "emergency" breaker and a list of which will work with the others.
#216692 - 01/23/16 11:09 AM Re: Designing for Power Outages [Re: renosteinke]
renosteinke  Offline
Blue Collar Country
Does anyone see a need for surge suppression on generator-fed circuits? Just how reliable is their voltage regulation (especially as your load varies)?
#216695 - 01/23/16 02:43 PM Re: Designing for Power Outages [Re: renosteinke]
gfretwell  Offline
Estero,Fl,usa
I doubt surge protection would buy you much on a typical portable generator. Your biggest problem is usually sags.
If I ever do decide to test my setup and I think of it, I will hook up my Dranitz and see what I have.
#216697 - 01/23/16 07:47 PM Re: Designing for Power Outages [Re: renosteinke]
Potseal  Offline
Saskatchewan
When the day comes to reno the basement I plan on installing a standby gen with an automatic transfer switch. How big of a standby gen I plan on using is the debate.
Reno, are you mostly concerned with surge suppression for ccts powering electronics? I think I would have a UPS ahead of the generator to deal with that concern.
A malfunction at the junction
#216698 - 01/23/16 10:32 PM Re: Designing for Power Outages [Re: renosteinke]
renosteinke  Offline
Blue Collar Country
Potseal, as I see it, the joker in the sizing decision is the starting current required for motors. When your overall load is as small as mine - or when, in my case, all I'm powering right now is one motor - that starting current matters.
Now, my generator, even when bought at a bargain price, cost me more than many similar capacity generators that I see in some retail outlets? Why pay more? Well, the biggest differences are in the noise made and the reliability of the voltage regulation.
There's my concern about voltage spikes: the voltage regulation of the generator as loads change. I would hate for a high-voltage spike when the furnace motor stops to cause harm to any electronics that might be on line.
Yes, a UPS would help; I had forgotten about that. That might be a solution.
Greg, I'd love to see what actual measurements show.
#216700 - 01/24/16 03:10 AM Re: Designing for Power Outages [Re: renosteinke]
gfretwell  Offline
Estero,Fl,usa
These days electronics are really not what I worry about. They usually have switch mode power supplies that tolerate anything from 100v to 250 or so. It makes them easier to sell around the planet.
AllClear
AllClear
Belmond Iowa US
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.025s Queries: 16 (0.005s) Memory: 0.8198 MB (Peak: 1.0017 MB) Zlib enabled. Server Time: 2017-03-28 15:58:38 UTC
