0 members (), 373 guests, and 12 robots.
HotLine1 #215943 08/16/15 06:25 PM
Got it. Didn't see the other pic
HotLine1 #215990 09/03/15 03:17 AM
That large conduit sticking out of the wall with the LB terminating into the panel appears to be supported by the panel. Shouldn't there be at least one hanger/support so that it's self-supporting (or maybe I missed seeing it)?
A malfunction at the junction
Dwayne
HotLine1 #215991 09/03/15 09:23 AM
That conduit does not go thru the wall, it goes to another LB into the large disconnect visible on the right.
It is an interesting 'install'.
HotLine1 #215993 09/03/15 01:01 PM
JBD Offline
This is not a recent installation.
Almost all of the equipment in the OP picture appears to be over 30 years old.
I don't know how long that panel has been mounted in that location, but that cover style has not been available for decades.
I know up through the 70s, and probably still today, it was common for 'industrial electricians' to use the NEC as a bookshelf decoration.
HotLine1 #215994 09/03/15 04:57 PM
JBD:
You're 100% correct, it is a dated job to say the least.
I've been in town for 14 years and never in that bldg. till the day I took the pic.
There is another pic here "Access" with a blocked troff in the same location.
