Page 1 of 3 1 2 3 >
Topic Options
Rate This Topic
#215737 - 07/11/15 06:48 AM Rebar Radar
renosteinke Offline
Loc: Blue Collar Country
I have it!
Yup.... Hand mr a roto-hammer, point me at a block wall, and I'll find the rebar, at least three tries out of four.
So ... here's the question ... anyone have any tricks for cutting rebar in the wall? My carbide core bits barely scratch it. There isn't room for a saws-it-all to get in there, and a cutting torch isn't part of my kit (maybe it needs to be!) Hole saws need a solid center for the pilot to guide the bit - and by the time I find the rebar, I've taken the center away.
Yesterday's project involved connecting an MCC to the gutter on the opposite side of the wall behind it. It's not like I could move the holes over an inch.
Top
#215739 - 07/11/15 10:57 AM Re: Rebar Radar [Re: renosteinke]
gfretwell Offline
Loc: Estero,Fl,usa
Diamond tools will cut rebar but it is very hard on the tool.
_________________________
Top
#215740 - 07/11/15 12:26 PM Re: Rebar Radar [Re: renosteinke]
twh Offline
Loc: Regina, Sask.
Depending on the size of the hole and the distance between the re-bar in both vertical and horizontal directions, it's probably unlikely that you could drill a number of holes and not hit re-bar. Sorry, but it might not be a super power. Still, you can change your name to "Rebar" and everyone will understand.
When the hole location has to be exact, plan for failure and hire someone with one of those wet coring machines. They cut re-bar nicely. They also do a sweet job of cutting hidden conduit in the cement.
It seems to me that if you stick a torch in a hole that isn't all the way through, it doesn't work.
Top
#215743 - 07/12/15 10:53 AM Re: Rebar Radar [Re: renosteinke]
electure Offline
Loc: Fullerton, CA USA
Some tool rental outfits rent core drills.
United Rentals is one of them. I see there is one in Blytheville.
Make sure to get the damage waiver (insurance).
Top
#215744 - 07/12/15 03:12 PM Re: Rebar Radar [Re: renosteinke]
renosteinke Offline
I see that $55 will get me a Bosch bit that is specifically designed for cutting rebar, and fits in the hammer drill:
Bosch RCSS2168
http://www.boschtools.com/Products/Acces...p;subCatId=1613
The idea seems to be that you use the usual masonry bits until you hit steel, use these bits to cut the steel, then resume with your usual bits. Interesting.
Has anyone used them?
A 1-1/8 bit ought to fit neatly into the hole you're making for 3/4" pipe. Looks promising.
For larger holes - my current project involves 3" pipe - I bet you can make smaller holes to the side of the main hole, cut the rebar, then break it out. Maybe. If you're going to do that, you probably want to remember that most rebar you'll find in block walls is about 3/8" diameter; maybe a smaller bit is in order.
I don't object to renting tools - core drills, btw, are also rented by Home Depot - but there is a time penalty. This job is just outside Memphis, so rental access is no problem.
Top
#215747 - 07/12/15 06:22 PM Re: Rebar Radar [Re: renosteinke]
HotLine1 Offline
Loc: Brick, NJ USA
As twh said, the core drills from the guys that do core & cutting work real great.
Mark out the location(s), make the call, watch them work, & pay the fee.
Works really painless & great.
Top
#215748 - 07/12/15 10:10 PM Re: Rebar Radar [Re: renosteinke]
gfretwell Offline
Loc: Estero,Fl,usa
I am not sure whee you see #3 rebar used for much of anything except the bottom and sidewall grid in a swimming pool. A doweled cell (block core poured solid) in Florida requires a #5 that hooks to the footer steel and the tie beam steel on top.
Top
#215751 - 07/14/15 06:13 PM Re: Rebar Radar [Re: renosteinke]
brsele Offline
Loc: Northern Ontario
If you're interested in a dry diamond core bit, I've received good service from this place: http://buydrillbits.com/.
But as Greg said, it is very hard on the drill. I'm pretty sure that I killed my Bosch.
Actually I have considered buying a proper water cooled Hilti core drill and offering my services. Anybody here know anything about that type of business?
Bruce
Top
#215753 - 07/14/15 11:38 PM Re: Rebar Radar [Re: renosteinke]
Potseal Offline
Loc: Saskatchewan
I used to work with a smaller construction outfit that tried doing their own core drilling. Eventually two things happened:
(1) depending on the location we first called in a guy to X-ray the wall or floor
(2) next we called in the guys who specialize in drilling cores
Worth every cent.
A malfunction at the junction
Top
#215754 - 07/15/15 08:17 AM Re: Rebar Radar [Re: renosteinke]
gfretwell Offline
Loc: Estero,Fl,usa
Pot seal has a valid point with the X-ray. If that rebar was not part of the engineering of the building, the builder would not have put it there. That is particularly true in floors.
Top
Page 1 of 3 1 2 3 >
SE cable question
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Who's Online
0 registered (), 96 Guests and 9 Spiders online.
SE cable question
Top Posters (30 Days)
Admin 47
HotLine1 43
gfretwell 19
Ruben Rocha 12
Trumpy 9
Newest Members
Stack, Scotto, Freecrowder, clee512, Jdscott2005
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
