Topic Options
Rate This Topic
#215472 - 05/15/15 06:32 AM Can two gfci share the same neutral
frank Offline
Loc: windsor ontario canada
Can a three wire split reptical be rewired for two GFCI recepticals.Will there be an issue since they share the same neutral.I dont typicaly do this kind work but belive the GFI's only care about down stream faults.The FPE DPST 15a GFCI bolt on breakers were just quoted at $460 each so we wont go there.Im getting differing opinions.
Top
#215473 - 05/15/15 07:38 AM Re: Can two gfci share the same neutral [Re: frank]
HotLine1 Offline
Loc: Brick, NJ USA
IMHO, if you terminate on the 'line side' of the GFI device there will be no issues.
_________________________
Top
#215474 - 05/15/15 01:07 PM Re: Can two gfci share the same neutral [Re: frank]
frank Offline
I didnt think so either following the logic that multipul GFCI recepticals everywhere go back to the panel on the same neutral anyway.The only diffence here is the proximity of the connection to the point of use.
Thanks
Edited by frank (05/15/15 01:08 PM)
Top
#215478 - 05/15/15 07:45 PM Re: Can two gfci share the same neutral [Re: frank]
JoeTestingEngr Offline
Loc: Chicago, Il.
Correct, fine on the line side, guaranteed trip on the load side.
Joe
Top
#215492 - 05/18/15 10:22 AM Re: Can two gfci share the same neutral [Re: frank]
brsele Offline
Loc: Northern Ontario
Check with your inspector if he'll allow two 15A GFCI receptacles. I'm assuming that this is for a kitchen.
Bruce
Top
#215785 - 07/18/15 12:18 PM Re: Can two gfci share the same neutral [Re: frank]
Shertok Offline
Loc: Hamilton, Ontario
Here is the ESA (Electrical Safety Authority)rules on changing from a split to a GFCI.This is for Ontario only. ESA Flash 14-02-FL PDF
Top
#215789 - 07/18/15 02:32 PM Re: Can two gfci share the same neutral [Re: Shertok]
twh Offline
Loc: Regina, Sask.
What a great idea! Two 15 amp circuits are, after all, better than one 20 amp circuit. Unfortunately, all the reasonable people are in one province.
Top
SE cable question
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Who's Online
0 registered (), 81 Guests and 7 Spiders online.
SE cable question
Top Posters (30 Days)
Admin 47
HotLine1 43
gfretwell 19
Ruben Rocha 12
Trumpy 9
Newest Members
KrmtFrg, Stack, Scotto, Freecrowder, clee512
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
