Admin 16
Old decora style outlets
by Admin. 03/25/17 11:40 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
fuse rejectors
by HotLine1. 03/24/17 07:53 AM
Another Forum Update
by Admin. 03/22/17 03:04 PM
Dining room plugs
by watersparkfalls. 03/21/17 10:31 PM
SE cable question
231,429 Are you busy
166,147 Re: Forum
160,604 Need opinion
0 registered members (), 77 guests, and 15 spiders.
Rate This Thread
#215440 - 05/09/15 05:29 PM Sub panel
sparkync  Offline
NC
I have a 200 amp Meter/combo with feed through lugs, outside with 5 double pole breakers. I am feeding out of back of that panel to a 200 amp main breaker panel directly behind it. The panel inside now becomes a sub panel, therefore I will have to run an insulated neutral from the outside panel to the inside (4 wire), but can still come off the "feed through" lugs to the inside main breaker, right??
I guess I can actually have a main lug panel inside instead of a Main breaker since I'm using the Main breaker outside thru the feed through lugs. Thanks
2017 / 2014 NEC & Related Books and Study Guides
#215446 - 05/10/15 03:42 PM Re: Sub panel [Re: sparkync]
gfretwell  Offline
Estero,Fl,usa
Yes it could be an MLO but the inside disconnect is not a bad idea, if for nothing else to avoid confusion from a "home inspector" down the road. The 4 wire feeder and the isolated ground bus is right.
#215453 - 05/11/15 04:06 PM Re: Sub panel [Re: sparkync]
sparkync  Offline
NC
Thanks Greg. Yes I'll probably go with the main breaker. I agree. Cuts down on confusion.
Lostazhell
Lostazhell
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.009s Queries: 15 (0.003s) Memory: 0.7499 MB (Peak: 0.8734 MB) Zlib enabled. Server Time: 2017-03-25 15:43:35 UTC
