Admin 19
fuse rejectors
by NORCAL. 03/29/17 01:44 AM
Old decora style outlets
by NORCAL. 03/29/17 01:41 AM
NFPA stuff
by gfretwell. 03/28/17 08:08 PM
Anyone hiring inspectors?
by HotLine1. 03/27/17 08:03 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
SE cable question
231,882 Are you busy
166,762 Re: Forum
160,878 Need opinion
0 registered members (), 90 guests, and 10 spiders.
Rate This Thread
#215315 - 04/07/15 11:21 PM Above ground pool
sparkync  Offline
NC
Been a while again since I've wired an above ground pool. Just wanting some refresher ideas.
The pool will be 52" high which will qualify it as a "permanent pool". Pump motor is 1 1/2 hp. on 120 volts.
If I run a 30 amp 4 wire 240 volt line in pvc conduit minimum of 18" deep, out to a 4x4 post and keep it at least 6ft. from the pool, set a small 4 or 6 circuit weatherproof panel, then come out the bottom of the panel and set a weatherproof bell box and put a 20 amp. 120 volt twist lock recpt. protected by a 20 amp GFCI breaker in the box ( with an in use cover of course) (or wire it direct), then come back out of the panel and put a regular GFCI outlet with an in use cover for the convenience outlet requirement, then dig a small trench around the pool and install #8 solid grd. wire and bond it at least 4 times to the frame of the pool then back to the pump, will this work? There's something about bonding the water I don't completely understand if you can comment on.
Hope this makes sense.
Thanks for the input.
2017 / 2014 NEC & Related Books and Study Guides
#215316 - 04/08/15 01:44 AM Re: Above ground pool [Re: sparkync]
gfretwell  Offline
Estero,Fl,usa
If the ladder is metal, you bond the water when you bond the ladder. They do make a plumbing fitting for the purpose if you have no metal parts in the water.
The rest sounds reasonable.
#215317 - 04/08/15 08:40 AM Re: Above ground pool [Re: sparkync]
shortcircuit  Offline
massachusetts
Here is a gadget for grounding water...
http://www.munroelectric.com/silver...mp;ds=mfr&ID=,Bond.Safe.680.Pool.Kit
shortcircuit
#215319 - 04/08/15 10:54 AM Re: Above ground pool [Re: sparkync]
HotLine1  Offline
Brick, NJ USA
Following all the above would result in a compliant install.
You may find that the skimmer unit supplied with the pool has a plate and lug to provide the water bond. IMHO, the AG pool mfgs should have to provide a point to connect the water bond, as it is required by the NEC.
#215821 - 07/22/15 11:40 AM Re: Above ground pool [Re: sparkync]
tsolanto  Offline
Long Island NY
Looks compliant to me
Attic Rat
Attic Rat
Bergen Co.,N.J. USA
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.012s Queries: 15 (0.002s) Memory: 0.7676 MB (Peak: 0.9084 MB) Zlib enabled. Server Time: 2017-03-30 18:39:26 UTC
