I have an old 60's to 70's vintage SCR variable speed drive that I thought would make a good DC power supply for powering simple circuits on a breadboard. I had a simple circuit made up that included a relay taken from salvaged electronic equipment. Once power was applied to the circuit the relay began to chatter. I took the relay out of the circuit and tested it with a 9V battery. It "clicked" indicating proper operation. As well, I verified that the contacts opened and closed with a DMM.
I tried the relay with the SCR VSD again this time out of the circuit. Once the power was applied it chattered like before. I tried a different relay and it did the same. I tried varying the voltage ever so slightly +/- and it made no difference. I then tried using a different straight 12VDC supply. Both relays functioned properly. So why does the SCR VSD cause these relays to chatter? I assume it has to do with the design. The previous owner was a knife maker who used this SCR VSD for DC motor speed control.
Is the DC power not "clean" enough for my application? Would a bridge rectifier and capacitor make a difference? Any suggestions would be appreciated.
A malfunction at the junction -------------------------------------- Dwayne
FREE switching power supplies are being thrown into the junk yard across the globe: ATX PSU from ancient PCs.
You can go to YouTube for any number of videos posted up by hobbyists.
All ATX systems are sophisticated enough to give you sweet DC voltages with trivial ripple.
+3.3 VDC +5.0 VDC +12. VDC
Even negative voltages:
-5.0 VDC -12. VDC
And these boxes are being placed at the curb every day of the week -- everywhere -- FREE.
Just troll through CraigsList or call around for 'e-waste' or some such.
Because of the basic (DC) voltages provided, it's possible to straddle them to derive difference voltages:
+12. VDC minus +5.0 VDC = +7.0 VDC ===> and so forth.
The provided voltages are EXACTLY those required by hobbyists for all digital circuits.
Because of industry standards, these PSU are also surprisingly efficient -- WAY superior to ancient solid state junk. There's absolutely no comparison.
AND, these PSU are much safer to toy with. They're totally enclosed and have their own fan and fuses.
I agree with Tesla on this one. I have one computer PS with 4 lighter sockets fitted for powering my RC chargers. My newer one was $4 at MPJA. I snipped the connectors off and lugged the conductors onto 5 way binding posts mounted to a piece of folded lexan. I also mounted a toggle switch, mini DVM, 2 LEDs, and a boost mode power supply. This gives me a 5VSB low current supply and an LED that are on as long as the PS is plugged in. Flipping the toggle lights up the second LED and turns on 3.3, 5, and 12 volt high current positive supplies, and low current -5, and -12 volt negative supplies. Connecting the boost regulator to the 3.3 volt output, and the mini DVM, gave me a variable 4-30 volt output with display. It gives me just about any DC supply that I need. I'll admit that the dual binding posts cost much more than the core PS cost, but I wanted the convenience. Your SCR supply will definitely need tons of filter capacitance, to be of any practical use. The ripple amplitude will be higher at lower average voltages. There are a couple clever circuits out there that put diode/SCR bridges in front of linear 3 terminal regulators. They phase control the SCRs to provide a voltage to the regulator, just above the input/output differential requirement. That way, the regulator power dissipation is minimized for a given current. Joe
I have one on my bench but one problem is on some of the supplies a fast change in the load like hooking up something big will trip them out. If you restart it with the load connected it is OK again
These supplies do need a start wire grounded to get them going. On the old AT types (2 flat board connectors)it is hooking the red and black together in that 3 pin plug (the cable with a white too) On the ATX with the rectangular 2 row board connector it is the green wire, usually #14, unless it is a Dell. They use a different pinout but it is still the green wire
The other whips constitute either legacy negative rails -- not used on any daughter card in the last quarter-century -- or are essential for smart switching of the PSU by the MSFT Windows program.
Purple = + 5 VDC -- hot at all times limited amps: Standby Green = + 5 VDC (fed by purple rail) during PC - 'off'
It's fed across a (stiff) resistor... and swings HIGH when its path to ground is broken -- the 'off' state for the PC.
Should you physically short this conductor to ground (any black) its new Boolean value ("0") triggers the PSU to spool up to full output -- specifically the +12 VDC and + 3.3 VDC rails. { with the smarter PSUs insisting on a load from the + 12 VDC rail -- ie CD-ROM drive/ HDD/ FDD. (If all three are missing then the shorted signal is a false one, and the PSU STILL won't fire up. This feature is not a universal one.)
Brown + 3.3 VDC feedback detection circuit. This puppy is typically snuck into the Molex connector. It's a totally 'unloaded' run of +3.3 VDC power that permits the latest brainy motherboards to evaluate and adjust the voltage drop hitting the memory and CPU rails. Beyond a certain threshold the voltage gap -- at the motherboard end between this conductor and the orange rail (the power run at +3.3 VDC ) will cause the CPU to instantly shut down -- without any notice at all. This is to preserve the 'machine state' -- data quality -- so that the PC does not run-on with flakey memory values. The brown conductor will appear to be seriously undersized. It's carrying virtually no actual current. Think of it as a perpetual DMM running in the backround.
Gray = Actually an analog-Boolean time-delay value. This, like brown, 'talks' to the CPU and memories. It's a delay line in their Boolean start up logic. It stops them from even beginning to load digital information until the +3.3 VDC 'rail' is steady and sweet. The designers could've simply put a time-delay sequence on the motherboard. Instead they've elected to force the PSU to tell the motherboard that enough time has elapsed -- AND -- verify that the + 3.3 VDC is sweet and stable; all of the capacitors are saturated with a DC potential.
Yet later designs have dropped much of the above -- and deliver +12 VDC only. This drastically simplifies the PSU -- as the CPU voltage is provided by a DC to DC power supply right next to the CPU on the board.
It's this element that has all of the big caps soldered in parallel from the Pentium 4 and onwards... which is another story.
The -12 is used by the serial port. We don't hook modems to them very much these days but they use a serial port for a UPS. The -5 was used for memory in some old XT era systems.
Well, I did as Tesla suggested and grabbed a few PC PSU's.
Then I started looking at some projects online and found someone's design where they made a variable DC voltage power supply using a PSU. I took that initial circuit and added a couple modifications and ended up with a Frankenstein's Monster version of a +12 VDC and +0-9VDC power supply. Behold...
Incase you were wondering that PSU is bolted directly to a gutted RCA ohms/volt analog meter turned on it's side. I replaced the original gauge with a 1-5 DC amp gauge. Probably fairly useless but it fit the existing hole.
The lay-out for the switches, ind. lights and outputs was mostly determined by existing holes. I tried to build this device as economically as possible and the looks speak for itself. As far as performance, it does exactly what it is was intended to do.
I haven't hooked it up yet but I made a little series regulator with an LM317 chip and a few pass transistors on a heat sink. The 5v & 12v seem to fulfill all of my needs so far.
That looks pretty good Potseal but I would do a couple things a little differently. 1.) Substituting an LM350 for the LM317, will allow > 4 amps with proper heat sinking. Since your +12V output is probably pretty beefy, you might as well be able to use more of it. 2.) Your supply is really about 1.25-9+ volts as-built. Should you really want closer to 0 output, you can use 1 or 2 diodes, in parallel with a cap, and then in series with a resistor to the -5V supply. Referencing the low side of the pot to the bypassed cathode's slightly negative voltage, offsets some or all of the 1.25 volt adjustment voltage. 3.) D2 is usually placed across the 240 ohm resistor when using a filter cap across the adjustment pot. The datasheet shows that 10uF gives about a 15dB improvement in ripple rejection. D2 protects from that cap discharging into the adjustment pin. BUT, if D2 is shown as protecting a battery load from causing damage if connected backwards, there should be a fuse before the + output terminal. 4.) While you don't have to use 100uF as an output cap, definitely use at least 1uF, or you risk oscillations with low capacitance loads. The 1uF or more swamps out that possibility. Joe
I have the transistors, already on the heat sinks (from IBM) and the LM317s are pennies each in quantity. I bought 20 a while ago. I got a bunch of 270 ohm resistors too at the same time so it makes a pretty cheap regulator. Most of the ones I have made are 3vDC, straight off the 317, to eliminate all of the batteries in stuff I have around here. If you run them off of a 5v wall wart the 317 never even gets warm. I seem to have collected a box of those wall warts over the years. USB A cords are handy too since that is the output of a lot of these wall warts, (lighter plug adapters etc)
Thanks Joe
I build circuits as often as I date supermodels... Which means I appreciate the input.
You are correct about the volts for my variable voltage. To be exact and using my DMM I measured 0.25 V at the low end and 8.99 V at the high end.
I will draw out the entire circuit with everything I used including switches and fuses and let you pick it apart (if you have a moment). I would like to get the most "bang for my buck" so if a few changes can improve the final product that would be great.
The following shows how I put the whole thing together. Please note that I used a 2.5 Kohm pot instead of the recommended 2 Kohm pot in the original variable voltage circuit (http://www.electronics-tutorials.ws/blog/variable-voltage-power-supply.html). Otherwise I followed it to the letter. I showed all the essential parts and labelled the conductors from the Molex connector that were pertinent to this diagram. There is one other yellow conductor that I used from a different connector to feed the relay coil.
OK, my thoughts: 1.) You already have jacks for +12V and 1.25-9V. Why give up one to have the other? If you are 5A capable, most bread boarding doesn't require that much current from all of the supplies combined. So you could run your +12 to the jack and an LM350T circuit, and just watch your combined output. Just change your variable output fuse to a 5A too. 2.) You didn't label your current setting resistor. If it's 240 ohms, you would be wasting most of your pot. A 390 ohm resistor would cause the supply to max out at around 9.25V. 3.)Keep the bodies of the resistors as close to the adjustment pin as possible since that is a very high impedance input. Twist leads going to the pot. If you add the 10uF cap for better ripple rejection, also add the extra diode across the 390 ohm resistor, cathode up. 1N4001, 1N914, 1N4148A would all be fine. 4.) The best place to learn how a chip works is usually straight from the mfg. http://www.onsemi.com/pub_link/Collateral/LM350-D.PDF OnSemi seems to have about the most complete datasheet for the LM350 these days. Page 2 is telling us that the reference voltage is typically 1.25V, adj. current 50uA, that I need to have around a 3.5mA load to regulate, and that I might be able to get 4.5A out of it. Page 5 shows how you can get more than 3A out of it(Fig.8), and how much more input voltage you need for different currents.(Fig.10) Figures 13 and 14 on Page 6, show how the 10uF helps. Pages 7 and 8 show useful applications. Joe
Today I had a few minutes and tried a little test by placing a 4 ohm resistor across the output for the variable voltage. Measured the variable voltage setting at 5 volts with a DMM before connecting it to the resistor. I expected to see the analog ammeter read about 1 amp but it didn't move. Then I measured the voltage drop across the resistor and it was less than half a volt.
Looks like I have a problem
I liken this to a weak battery that without load reads a proper voltage but as soon as a load is applied the voltage drops to almost nothing.
I placed a 10 ohm resistor across the outputs of the + 12V output (I haven't made all the changes that Joe suggested, yet) and sure enough the ammeter showed over 1 amp of DC currrent.
Therefore something isn't right with my variable voltage circuit. Capacitors? Voltage regulator? Any help would be appreciated.
Have you checked your relay contact? What kind of heat sink do you have the LM317T mounted to? The chip has internal thermal limiting and will dial back rather than self destruct. Joe
Originally it was a minor mix-up that caused the problem. A somewhat embarrassing mistake.
Since I had to make some changes I went all out and revamped the entire circuit. I took Joe's suggestions and changed some of the components. As well, I simplified and streamlined the circuit board wiring and component placement and cut the space needed in half. Lastly, I made a separate compartment out of a repurposed AC Adaptor case to hold the output fuses on the outside of the device for easier access if they blow.
All in all my dumb mistake ended up being the motivation for an improved design.
Thanks to all who helped with good advice. I appreciate it.
The next upgrade will hopefully include a digital DC voltmeter
