Page 1 of 2 1 2 >
Topic Options
Rate This Topic
What's behind the door???
Image Details
Poster HotLine1 Offline
Posted 02/22/15 03:59 PM
Description
Found doing a walk-thru on a complaint
Have to check this out further next week.
Dimensions 900x1200
Size 123.03 KB
UBBCode
Thumbnail
Medium
Full
Comments
#215026 - 02/22/15 04:45 PM Re: What's behind the door??? [Re: HotLine1]
HotLine1 Offline
Loc: Brick, NJ USA
OK, it's back to the sideways pics!!!
(Fixed - Admin)
Edited by Admin (01/24/17 05:00 PM)
Top
Super Rod Cable Installation Tools
Super Rod Cable Rod System
Super Rod Cable Rod System -
Voted
Best Product of the Last 50 Years by members of NICEIC
#215027 - 02/22/15 05:51 PM Re: What's behind the door??? [Re: HotLine1]
gfretwell Offline
Loc: Estero,Fl,usa
I haven't got to OMG yet. How was the 250 stuff?
_________________________
Top
#215028 - 02/22/15 10:50 PM Re: What's behind the door??? [Re: HotLine1]
Scott35 Offline
Loc: Anaheim, CA. USA
John,
Is this supplied by a 1 Phase 3 Wire System, or a 3 Phase 3 Wire Corner-Grounded System?
BTW, Notice that most of the Grounded Conductors for the Branch Circuits are Fused.
The only one that is not Fused is at the bottom of the Bus Kit.
Nevertheless, quite a find!!! thumbs clap
--Scott (EE)
Top
#215029 - 02/23/15 06:48 AM Re: What's behind the door??? [Re: HotLine1]
HotLine1 Offline
Loc: Brick, NJ USA
I have to look at this in more detail.
It looked like the neutrals are all fused, except the tap off of the top buss.
It's in an old school bldg. More to come.
Top
#215030 - 02/23/15 07:26 AM Re: What's behind the door??? [Re: HotLine1]
Tesla Offline
Loc: Sacramento, CA
I seriously doubt that the 'neutral bus' is fused -- it's a corner grounded delta -- hence the fusing to the 'neutral' it's a grounded 'hot.'
I absolutely HATE to sling around the term 'neutral' in such schemes. While a corner grounded delta certainly has been pulled over to ground potential, it absolutely has circulating current pumping in and out of it -- at a tempo far beyond the residual imbalances typical of a center tapped residential service.
[ Unlike a center tapped Service drop, one dares not ever break the bonding to the ground while power is applied. What's bad for a center tapped ground is horrific for a lifted corner on a delta. ]
[ EUSERC hates this old time scheme so much that you'd need a Presidential Executive Order to have a new one hooked up. Emergency responders will always mistake the grounded corner -- from the layout of the panel -- to be that of a single phase, center-tapped scheme. Not good. ]
Off hand, it smells like a distribution panel for site lighting.
Which is exactly the kind of system that would run on and on for years without an upgrade/ overhaul.
I'd expect that the service was some ancient 240 delta.
That far back 480 was just not done for such facilities.
Edited by Tesla (02/23/15 07:33 AM)
Top
#215036 - 02/24/15 01:43 AM Re: What's behind the door??? [Re: HotLine1]
Tesla Offline
Loc: Sacramento, CA
Since EUSERC hates corner grounded delta Services, I've never run across a single one.
I'd be interested to hear if a voltage tick reads 'hot' around such grounded legs of the power flow.
Let us know.
Tesla
Top
#215047 - 02/24/15 01:36 PM Re: What's behind the door??? [Re: HotLine1]
gfretwell Offline
Loc: Estero,Fl,usa
I used to see corner delta on sewer lift pumps. As soon as I figured out what it was, I never saw anything unusual about it. It seems to have a certain elegance to it. A grounded conductor is a grounded conductor. It is simply an arbitrary decision at which point we ground the transformer secondary. I would be a lot more concerned with the center of a wye when you have reactive loads than a corner delta. It will only draw nominal circuit current. The main code/listing issue is that there is 240v to ground so the 2 pole breakers need to be "delta" rated.
Top
#215052 - 02/24/15 06:38 PM Re: What's behind the door??? [Re: HotLine1]
LarryC Offline
Loc: Winchester, NH, US
Does it look to anyone else that many of the fuses have been replaced over the years? The labels on the fuses look too clean to be original. Why have they been replaced?
Top
#215068 - 02/25/15 09:31 AM Re: What's behind the door??? [Re: HotLine1]
gfretwell Offline
Loc: Estero,Fl,usa
They look like they are FRNs so they may have been instant blow before and someone decided a delay fuse was a better option.
Top
Page 1 of 2 1 2 >
SE cable question
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Who's Online
0 registered (), 95 Guests and 10 Spiders online.
SE cable question
Top Posters (30 Days)
Admin 47
HotLine1 43
gfretwell 19
Ruben Rocha 12
Trumpy 9
Newest Members
Scotto, Freecrowder, clee512, Jdscott2005, FAIZAN
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
