Admin 19
Anyone hiring inspectors?
by HotLine1. 03/27/17 08:03 AM
Old decora style outlets
by Admin. 03/25/17 11:40 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
fuse rejectors
by HotLine1. 03/24/17 07:53 AM
Another Forum Update
by Admin. 03/22/17 03:04 PM
SE cable question
231,643 Are you busy
166,537 Re: Forum
160,725 Need opinion
0 registered members (), 62 guests, and 10 spiders.
Rate This Thread
#214218 - 10/30/14 01:46 AM Attachment point for residential service
bigpapa  Offline
canada
Why do they sell these?
Can you use one of the knobs with the lag screw on the back or as I interpret the code, a long bolt through structural wood with a nut/washer on the back.
Incoming overhead cable is about 40ft. 6-112(6) says bolted but is a lag screw considered a bolt?
Im upgrading a 100A to 200A and don't want to rip the wall open unless absolutely necessary. I know the lag type insulator would hold but if they are not allowed by code, why do all the suppliers have lots on the shelves?
#214219 - 10/30/14 02:08 AM Re: Attachment point for residential service [Re: bigpapa]
Tesla  Offline
Sacramento, CA
They are traditional for overhead runs between house and barn... and much else... on the customer's side of the meter.
The NEC does not cover Poco rules.
And the Poco rules dictate everything from the Service back up the line towards their distribution drop.
Locations
Hardware
Conductors
Clearances
This is one area where a j-man has to make both inspectors happy. (County inspector & Poco inspector)
Out my way, the Pocos reject all manner of gear that qualifies by the standards of the NEC. (EUSERC)
Tesla
#214220 - 10/30/14 02:24 AM Re: Attachment point for residential service [Re: bigpapa]
bigpapa  Offline
canada
Anybody here from BC Canada? Guess I will call the BCSA inspector about this.
#214223 - 10/30/14 03:27 PM Re: Attachment point for residential service [Re: bigpapa]
dougwells  Offline
kamloops BC Canada
For a 200 amp service, you will need the bolt through, At one time our inspector said that if the service was 100 amps and a short run to the pole they would accept the screw in type.
#214224 - 10/30/14 06:33 PM Re: Attachment point for residential service [Re: bigpapa]
brsele  Offline
Northern Ontario
So in BC, do you really have to rip open the wall in a house when doing a 100A to 200A upgrade? (Obviously we're only talking about houses with an overhead service supply.)
I'm just curious.
#214225 - 10/30/14 10:10 PM Re: Attachment point for residential service [Re: bigpapa]
dougwells  Offline
kamloops BC Canada
Yes external masts have to be a bolt through securing method . attached in 3 places and the most highest clamp secured to a rafter frown
#214241 - 11/01/14 02:41 AM Re: Attachment point for residential service [Re: bigpapa]
bigpapa  Offline
canada
I talked to the inspector this morning and he confirmed that bolted through is all that is accepted for 100A or 200A incoming cable attachment point.
The_Lightman
The_Lightman
Orlando, Fl, USA
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.016s Queries: 15 (0.003s) Memory: 0.7834 MB (Peak: 0.9401 MB) Zlib enabled. Server Time: 2017-03-28 13:57:56 UTC
