Admin 16
fuse rejectors
by gfretwell. 03/23/17 01:12 PM
Another Forum Update
by Admin. 03/22/17 03:04 PM
Dining room plugs
by watersparkfalls. 03/21/17 10:31 PM
TRUE POWER
by jraef. 03/21/17 09:13 PM
WEG CFW-11 Frequency Inverter
by jraef. 03/21/17 08:50 PM
SE cable question
231,301 Are you busy
166,025 Re: Forum
160,511 Need opinion
0 registered members (), 53 guests, and 10 spiders.
Rate This Thread
#214152 - 10/17/14 03:06 PM 3-way photosensor switch control
tanderson93  Offline
KS
I am a student in mechanical engineering working on a personal project for which I need to use a 3-way switch triggered by a photosensor (one sensor for the on-position, and a different one for the off). Could someone point me to some resources that would help me to understand how this is done and how the circuitry is designed?
Object in the top frame blocks the line of sight of sensor one, activating the sensor to turn switch an arbitrary circuit on. Object moves to its position in frame 2 where it blocks the line of sight of sensor 2, turning activating the switch to turn the
#214153 - 10/17/14 03:33 PM Re: 3-way photosensor switch control [Re: tanderson93]
gfretwell  Offline
Estero,Fl,usa
You will not be using a regular off the shelf IR detector unless you add some extra logic.
If you used the detector to pick a relay and then used a "D" flip flop it would work. You could also do it all with relays if you want to go "old school".
#214154 - 10/17/14 04:15 PM Re: 3-way photosensor switch control [Re: tanderson93]
tanderson93  Offline
KS
I'm sorry, but could you clarify that some? My knowledge base is in mechanical systems - I could design this to be entirely mechanical but then I run into an issue when I am machining the parts for the thing. They would end up being overly complex for the system I am designing. Electric control seems a more streamlined and efficient method. But, again, I know next to nothing about the subject, so I need it expressed to me in layman's terms. Or if you could point me to where there are some resources for me to study, I would appreciate that as well.
#214155 - 10/17/14 05:41 PM Re: 3-way photosensor switch control [Re: tanderson93]
gfretwell  Offline
Estero,Fl,usa
OK do you want one detector to always be for "off" and the other "on" or do you want it to toggle whenever either is triggered?
Considering your situation, a relay solution may be the easiest.
This is really beyond the scope of this BB but I can send you a private message.
#214157 - 10/18/14 02:00 AM Re: 3-way photosensor switch control [Re: tanderson93]
JoeTestingEngr  Offline
Chicago, Il.
http://www.mpja.com/Opto-Interrupter/productinfo/18028%20OP
Are you going to use opto-interrupters like these? You could use the outputs to steer the input of a schmitt trigger circuit, biased half way between the on and off thresholds. Same thing with a comparator with hysteresis. Two analog options. You can drive an R-S flip flop or D or J-K flip flop with preset and clear pins as digital options. Then there are the relay options. So many simple ways to do it, depending on the voltages that you wish to work with and your actual application.
This would be better posted down in the technical area.
Joe
#214159 - 10/18/14 04:45 PM Re: 3-way photosensor switch control [Re: tanderson93]
HotLine1  Offline
Brick, NJ USA
Wow, that is some real deep stuff there Joe!
You lost me at the Schmitt trigger......
I'm with Greg; relays.
#214160 - 10/18/14 08:19 PM Re: 3-way photosensor switch control [Re: tanderson93]
gfretwell  Offline
Estero,Fl,usa
A Schmitt trigger is just a switching device that responds to a slowly changing input with a clean turn on or off at a certain point in the input slope.
With photo detectors, an op amp is a pretty good way to accomplish this, using a feedback resistor to square the output up.
#214161 - 10/18/14 09:17 PM Re: 3-way photosensor switch control [Re: tanderson93]
Chicago, Il.
I would modify Greg's description to mention 2 different points on the input slope. For instance, with a 10V supply, it might take >=6V to turn the gate on, but <=4V to turn it off. 2, 10K resistors could be placed in series across the supply to place 5V on the input. Momentary switches across those resistors, (probably with their own series resistors to prevent shorting out the PS), would be able to switch the output back and forth.
I would also agree with you both on relays if our OP is using line voltages and large gaps. I picture those photocell circuits that ring the bell when you walk into stores. 2 of those and 2 relays or 1 latching relay, would be all that's needed for what I think he's trying to do. But for small gaps and logic level supplies, I picture a flip flop with preset and clear driving an opto, SSR, or relay via a driver ckt.
Joe
#214162 - 10/18/14 10:21 PM Re: 3-way photosensor switch control [Re: tanderson93]
gfretwell  Offline
Estero,Fl,usa
In the thermostat I use for my spa, using an LM324 op amp for the trigger, my feed back resistor is pretty big (1m pot) so the on and off points are pretty close together. +/- < 1 degree f on a thermistor sensor (automotive water temp sensor)in a Whetstone bridge with two 10ks on the far side.
We really need to know more about what kind of photo sensor he is using and what the outputs are. I agree a latching relay is probably the lowest part count solution if he can drive it from the sensors and he wants one to always be "turn on" and the other one always "turn off". You can get latching relays that operate around 1 ms so if this is not really something where things are screaming by, it should work.
#214163 - 10/19/14 12:52 AM Re: 3-way photosensor switch control [Re: tanderson93]
electure  Offline
Fullerton, CA USA
I've used off the shelf photosensors on the TEST mode for things like gate buzzers and driveway alarms. They shut off almost immediately when no motion is sensed.
If you install 2 of them, hook both the switch legs up to the primary of a 'Touchplate' transformer, and the secondary to a Touchplate (latching) relay to control the load it should take care of the situation.
...and it would use all unmodified UL listed parts
Samurai
Samurai
Fl.
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.018s Queries: 17 (0.004s) Memory: 0.8202 MB (Peak: 1.0054 MB) Zlib enabled. Server Time: 2017-03-24 10:10:04 UTC
