1 members (gfretwell), 139 guests, and 9 robots.
sparkync #213608 06/08/14 09:11 PM
A while back, I did some experimenting with the LFNC into PVC M/A thing.
After some failures I ended up sanding both the flex and the M/A with 220 grit sandpaper, priming each with PVC primer, applying Light Bodied PVC Cement to both, and assembling it.
I left it overnight to cure. When I came back to test it, the flex pulled right out of the PVC fitting.
The glue hadn't bonded to the flex.
I gave up at that point.
sparkync #213611 06/09/14 02:00 AM
I use Otey all purpose with primer and you can't pull one out, at least with the force it takes to pull out a regular LNFC fitting.
If this stuff was white it would be Spa Flex and they put pools together with it.
