211
I was recently reading a US DIY Electrical book and it had a picture of a tool called a cable ripper, for use with NM type cable. Tell me, do you own and use one of these tools, or do you prefer to use sidecutters to strip your cables?.
Posts: 466 Likes: 1
I prefer the strippers made for NM cable that cut the outer jacket. After cutting you just slide the jacket off instead of sliding the ripper up the cable and then ripping it downward toward the end. The pair I have is from Ideal with a cutter for 14-2 and also 12-2, Klein also makes a pair.
When I did a lot of NM-B work I would use the cable ripper but I would cut off one side of the bottom so you did not have to slide it up the cable, good when cutting in for panels.
Do the stripers that Jim mentioned work to strip long lengths?
We use a utility knife http://www.mytoolstore.com/klein/44100.html when we strip romex. It is much quicker and takes a little practice to get used to but once you use it, its faster than using a cable ripper. Anybody else? [This message has been edited by Sandro (edited 02-01-2003).]
I'm with Sandro. I have always used a utility knife and its pretty much standard practice here in the San Jose/San Francisco area. We always strip the cable after they are installed in the boxes.
Curt
Curt Swartz
When I wired new housing(many years ago)I used a sheetrock knife, it was much faster then a stripper
Larry
Posts: 466 Likes: 1
iwire,
Yes they do work for long lengths, although I sometimes will make 2 or 3 cuts and slide off each piece. I still think that this is faster than a ripper and much safer than a utility knife.
The NM cutters also have a stripper in the tip along with a looping hole.
The rippers seemed OK for __-2 cable, but were not good for __-3. (As in 12-2 vs. 12-3...)
A knife does a nice, quick job. However...
Sharp blades slice; Dull blades slip Be real careful when Doing the ol' cable-strip!
Lighthouse, I am probably going to sound pretty dumb, by saying this, but, How do you use the Cable- Ripper?. Your help would be appreciated.
