1 members (Scott35), 524 guests, and 23 robots.
#21213 01/29/03 12:09 AM
big lug Offline OP
How far apart do you staple romex. I'm rewiring my house and was needing some advice. Thanks in advance.
#21214 01/29/03 12:15 AM
Within 12" of the box and every 54" after that.
2002 NEC 334.30
#21215 01/29/03 07:12 AM
code aside,
i staple (insulated) single runs loosley, at every 2' or so. anything more than 2 runs and i use stackers.
the intervention of 'other trades' has intimidated me to this point.
#21216 01/29/03 09:00 AM
Keep in mind...
If you are using single-gang non-metallic boxes without internal clamps, you have to staple it within 8" of the box. 314.17 (C) ex. I like the stackers also. They make for a nice looking installation.
[This message has been edited by Redsy (edited 01-29-2003).]
#21217 01/29/03 08:35 PM
the minimums are with 8" of a NM box without clamps or 12" from a box with clamps and every 4 1/2 fett there after. Never staple on a twist, keep romex flat.
I once had a helper that could not grasp this concept so we had to go to stapling "hammer length apart", I kid you not...
#21218 01/29/03 09:54 PM
4' works nicely with usual stud spacing and plywood sizes.
