Admin 19
fuse rejectors
by NORCAL. 03/29/17 01:44 AM
Old decora style outlets
by NORCAL. 03/29/17 01:41 AM
NFPA stuff
by gfretwell. 03/28/17 08:08 PM
Anyone hiring inspectors?
by HotLine1. 03/27/17 08:03 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
SE cable question
231,882 Are you busy
166,762 Re: Forum
160,878 Need opinion
0 registered members (), 90 guests, and 10 spiders.
Rate This Thread
#212073 - 12/09/13 03:30 AM Antique Outlet Stand
Admin  Offline
NY, USA
(posted for Frank DeWitt)
I fixed up a old Outlet Stand. When I reassembled it I had to select carefully from my old duplex outlets to get two that were small enough to fit. The outside of the box is 4 1/16 X 2 X 1 3/4 and there is a outlet on each side!
Does anyone know anything about this? Have you seen one before?
It looks like it was made in the 30s. It must have been so you would have a convenient place to plug in your laptop and phone.
Frank DeWitt
#212082 - 12/09/13 11:56 PM Re: Antique Outlet Stand [Re: Admin]
HotLine1  Offline
Brick, NJ USA
Interesting! Now,what purpose was that originally intended?
#212089 - 12/10/13 12:39 PM Re: Antique Outlet Stand [Re: HotLine1]
Frank DeWitt  Offline
Bloomfield NY
That is what I would like to know. I do know that at this time table outlets were sold. I have seen a number of small china dogs with a felt base and a couple of outlets in them.
I have also seen a "Table outlet"
I can only assume that wall outlets were few and having AC power was something to be proud of.
Frank
#212090 - 12/10/13 05:25 PM Re: Antique Outlet Stand [Re: Admin]
HotLine1  Offline
Brick, NJ USA
Frank:
Those are some really nice items!!
FWIW, my wife would have a fit if I had the stand & plugged my laptop (or anything else) into that. She hates to see any cords!! She would prefer a receptacle by everything that she has to plug in!
The dogs are sharp.
#212091 - 12/10/13 06:37 PM Re: Antique Outlet Stand [Re: Admin]
HotLine1  Offline
Brick, NJ USA
Frank:
The dogs are sharp.
#212180 - 12/18/13 01:10 AM Re: Antique Outlet Stand [Re: Admin]
harold endean  Offline
Boonton, NJ
John,
I think that receptacle stand would work just fine for a coffee pot on a table or that new fangled invention the TV set. The plugs were set down low, but with the stand, you can have an outlet right up high by the table. smile
#212181 - 12/18/13 01:11 AM Re: Antique Outlet Stand [Re: Admin]
Boonton, NJ
Frank,
Those old electrical items are really neat. Where did you ever find them?
#212197 - 12/19/13 01:13 PM Re: Antique Outlet Stand [Re: harold endean]
Bloomfield NY
Originally Posted by harold endean
Frank,
Thanks, I spend WAY to much time on Ebay. Actually I didn't buy the table outlet in the box, I just saved the picture. Believe it or not, there was a bidding war. People are collecting this stuff.
BTW one of those dog outlets is on ebay almost continuously if any of you would like one
Frank
#212201 - 12/19/13 04:08 PM Re: Antique Outlet Stand [Re: Admin]
Tesla  Offline
Sacramento, CA
When retail electricity was first brought into homes -- existing homes -- the common practice was to remove the base boards right at the floor line -- and BX it in.
The studs could be drilled/ notched -- balloon construction was often to hand -- and you'd be shocked as to how many homes eighty-years ago had no insulation. Everyone just wore a lot of wool clothing -- and thought nothing of it.
The crazy idea of waking up to a warm house -- is about as modern as Romex.
With power only available right down at the floor, short runs to a switched pole lamp made perfect sense. (BTW, the VERY first receptacles used Edison screw type bases. He had the patent -- and was installing his invention at every location possible.) As you might imagine, screwing into a wall socket fell out of favor the second the straight blade plug entered the market.
Now these gadgets had two uses. They could be powered by an ancient Edison screw type receptacle -- still sometimes found -- typically found in 'old-rich' homes -- while providing a sweet transition to the new straight blade receptacles -- now at a table top height -- or whatnot.
Or, they could be powered by a base board straight blade receptacle. In so doing, they'd eliminate the repeated need to bend clear down to the floor to remove this or that plug -- pretty hard on the elderly.
And the first electric appliances came into use... starting with the old hot plate. No-one wanted to leave such a beast plugged in when they were away.
This also extended to coffee makers.
Since old kitchens were never wired -- these gadgets were the perfect stop gap. You'd set them near the breakfast table -- and power up the coffee maker right there.
Dog type extension cords would be DIY'd from the base board up to a kitchen counter. The users were instructed to NOT leave appliances plugged in when not in use, to NOT use extension cords as permanent wiring.
This logic is still in the NEC. This is when and where it got started. These are the original extension cords -- which for most did represent quasi-permanent wiring.
As time went by, BX and Romex retrofits made the very need for these -- under gauged -- DIY wiring methods dated.
( Having routed the BX, the installers could tack the base board back in place -- repairing, painting as needed. They could get in and out in no time... if hand augering was your idea of high speed.)
BTW, the VERY first electric drills were introduced in the twenties. (Metabo in Germany -- a contraction of "to drill holes" in German -- and Black & Decker in the USA) Both firms came out with electric drill motors at almost the same instant. These were huge tools -- with lousy performance. But, lousy beats zero anytime.
(Porter Cable came out with the first electric side winder saw -- with gear reduction, IIRC, at about the same time. The very first efforts went with direct drive -- off of a universal motor.)
The mass production of universal motors changed the world -- and no where more so than the construction trades.
Tesla
#212203 - 12/19/13 07:02 PM Re: Antique Outlet Stand [Re: Admin]
Texas_Ranger  Offline
Vienna, Austria
Actually it's "Metallbohrdreher", a quaint phrase that roughly translates as "rotary metal drill". Metabo didN't invent the power drill either, they only made a very successful one. The machine itself was actually invented by Emil Fein as early as 1895.
Attic Rat
Attic Rat
Bergen Co.,N.J. USA
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.020s Queries: 16 (0.003s) Memory: 0.8215 MB (Peak: 1.0020 MB) Zlib enabled. Server Time: 2017-03-30 18:39:41 UTC
