1 members (Scott35), 481 guests, and 10 robots.
Page 3 of 3 1 2 3
Originally Posted by LarryC
Is there an inverter available that can operate in grid tie OR island mode? That would solve the issue. Even if you had to turn the inverter off and then back on to switch between modes.
The Outback Radian...
http://www.outbackpower.com/outback-products/inverters-chargers/item/radian-series-gs8048
Ill have to check but I do believe Outback FX series does. I have only used them on off grid systems but the menu options are supposedly there
The Outback GFX series is grid/off grid enable as well. Haven't work with the Radian system yet.
http://outbackpower.com/downloads/d...b_022013_gtfxgvfxseries_specsheet_lr.pdf
Page 3 of 3 1 2 3
