BigB Offline OP
Having just adopted 2 code cycles there's a lot of stuff to absorb, and easily forgotten as well. Are the TR receps required everywhere? We are trimming a reptile enclosure in a residential back yard tomorrow, it has a work station with receps and some receps for heaters and fridge (for the reptile food). We are of course GFCI protecting everything but I am unclear on the TR requirements. This is basically a 10 x 20 shed built on a slab with a sub panel and insulated walls covered with siding on both sides. The reptiles (Iguanas) are going to be in cages with doggie doors to the outside, and as far as I know they won't be trying to stick things into the receps.
I am not sure that 210.52 requires a receptacle there so 406.12 does not seem to apply.
IMHO, no TR required. However, you may want to check with your local AHJ
BigB Offline OP
Greg, what about 210.52(G)(1)accessory buildings?
I would say that the receptacles get to be TR (tamper resistant), WR (weather resistant), AND GFCI protected.
Just bought some TR / WR GFCI receptacles. $20 each. Safety is nice- but remember when you could get a duplex receptacle for half a dollar? The '90's were NOT that long ago!
Big Bob got me. That is a 2014 change I missed.
OK, someone has the '14 changes??
Is the reptile room private of commercial?
Sorry I meant 11. We are still on the 08.
NFPA has released the 2014 Analysis of Changes tho. The books are on the street now. ($65)
Living in a place that is always one to two cycles behind can make these things confusing.
BigB Offline OP
It looks like TR for everything except the fridge and the ceiling then.
