1 members (ale348),
302
14
Having just adopted 2 code cycles there's a lot of stuff to absorb, and easily forgotten as well. Are the TR receps required everywhere? We are trimming a reptile enclosure in a residential back yard tomorrow, it has a work station with receps and some receps for heaters and fridge (for the reptile food). We are of course GFCI protecting everything but I am unclear on the TR requirements. This is basically a 10 x 20 shed built on a slab with a sub panel and insulated walls covered with siding on both sides. The reptiles (Iguanas) are going to be in cages with doggie doors to the outside, and as far as I know they won't be trying to stick things into the receps.
Posts: 9,923 Likes: 32
I am not sure that 210.52 requires a receptacle there so 406.12 does not seem to apply.
Posts: 7,381 Likes: 7
IMHO, no TR required. However, you may want to check with your local AHJ
I am not sure that 210.52 requires a receptacle there so 406.12 does not seem to apply. Greg, what about 210.52(G)(1)accessory buildings?
Posts: 5,445 Likes: 2
I would say that the receptacles get to be TR (tamper resistant), WR (weather resistant), AND GFCI protected.
Just bought some TR / WR GFCI receptacles. $20 each. Safety is nice- but remember when you could get a duplex receptacle for half a dollar? The '90's were NOT that long ago!
Big Bob got me. That is a 2014 change I missed.
OK, someone has the '14 changes??
Is the reptile room private of commercial?
Sorry I meant 11. We are still on the 08.
NFPA has released the 2014 Analysis of Changes tho. The books are on the street now. ($65) Living in a place that is always one to two cycles behind can make these things confusing.
It looks like TR for everything except the fridge and the ceiling then.
