1 members (Scott35), 143 guests, and 10 robots.
#21060 01/27/03 08:16 AM
Redsy Offline OP
I have to retro-fit an exhaust duct to a previously installed, un-ducted bath fan.
The orientation of the fan would require about 180 or so degrees of bend, and about 8 ft. of straight run. (The Broan website is down, so I cant look up the maximum values.) Anyone have any insight?
#21061 01/27/03 11:10 AM
Redsy:
I am able to get through to http://www.broan.com/ without trouble.
If you still can't get through, tell me what you have in mind and I'll look it up for you.
#21062 01/27/03 11:25 AM
Redsy:
If Broan is down, try Nutone, the stuff is basically the same, or close for your purposes.
Off the cuff, I think your numbers would get by, or can you change the fan to 80CFM.
#21063 01/27/03 02:48 PM
Redsy Offline OP
Thanks, guys.
I was able to get on today. Still, at the FAQ site, the data I wan't wasn't available. I'll try the site again and look for specs.
