by NORCAL - 03/19/24 05:11 PM
1 members (Scott35), 267 guests, and 17 robots.
Page 12 of 14 1 2 10 11 12 13 14
Meadow #215912 08/14/15 09:40 AM
Meadow Offline OP
Thank you DSK, awesome pic! smile
Meadow #216048 09/18/15 04:24 AM
dsk Offline
They told me, it is safer with the transformers at the ground, than in poles. I'm not so sure!
Picture taken from the bus to my job this morning.
Meadow #216054 09/19/15 08:33 PM
Meadow Offline OP
Yikes, thats not very good. I agree, pole is better.
Meadow #217289 06/13/16 03:37 PM
dsk Offline
Maybe not always.
The lightning has hit and the grounding wire is off! As long as I stay on the ground this should be safe. or ??
I post this, and sends link to the owner of the network, and asks for comments and followups on this page.
As far as I know this supply is 3 phase delta 22kV with no fixed grounding of the transformer winding. I hope we may get some response here. thanks
Meadow #217411 07/21/16 11:04 PM
Meadow Offline OP
Awesome thanks! smile By chance, would you happen to know how the 22kv system is earthed at the substation?
Meadow #217416 07/22/16 07:02 PM
dsk Offline
Normally not.
Meadow #217417 07/23/16 04:36 AM
dsk Offline
By the way, last time I visited USA, I registered high voltage with 3+N and only 3 wires (connected to the transformers to the consumers network), eg in different parts of CA. What will be the difference, and normal voltages? (Reference to other threads or pages? since this not fits this thread?)
dsk
dsk #217440 08/06/16 02:22 AM
dsk
What are you referring to as "high voltage"?
For voltages in CA, the largest utility is PG&E, & here is a link to the "Greenboook" which lists the voltages they supply.
http://www.pge.com/includes/docs/pd...greenbook/greenbook_manual.pdf#Section_2
Meadow #217444 08/06/16 06:04 AM
dsk Offline
Huge document, I will need some time to read all that. :-)
This picture http://tinyurl.com/hs7q4wy shows a pole, sometimes the supply has 3 wires, and service neutral, sometimes only the 3 wires. The transformer primary is connected between N and one supply wire, or 2 of the supply wires. What use to be the primary voltage for these transformers?
dsk
Meadow #217645 09/29/16 09:36 AM
Meadow Offline OP
In California 16kv is very common followed by 12kv, the lines are usually 3 wire on the HV and have no neutral. Transformers are connected L-L or delta. There are some 4 wire lines where the HV neutral is insulated, and those are typically 2.4/4.16kvY.
Outside of California 4 wire is common for the HV with the neutral multi grounded (multi grounded mostly forbidden in California). Typical voltages are 7.2/12.47Y, 7.6/13.2Y, 7.9/13.8kvY, 13.2/23kvY, 14.4/25kvY and 19.9/34.5kvY. 2.4/4.16Y and 4.8/8.36kvY often found on older systems which are now obsolete.
