390
14
First off, Donovon, welcome to ECN, mate! I must say, in all my time here, I have never seen a connector like the one you've posted in your 3rd picture, were these actually made for that purpose? I'm also a tad worried about that plug hanging in mid-air, especially when it looks like it's connected to that lighting circuit. Cheers, Mike T.
Donavan,
I too welcome you to the board, and you do have some creative (and dangerous) wiring there.
To me that looks an awful lot like a 3-way trailing socket, i.e. supposed to be part of an extension lead. It could also be a plug-in 3-way adaptor with the prongs cut off. Anyway, was that contraption backfed by stuffing wires into the holes on the left?!?
I look at the third photo and someone did insluated the short peice of conductor with eletrique tape to used for support the triple tapper receptale.
Ya got a good catch there and I have see some crazy stuff over here in France.
Merci, Marc
Posts: 7,381 Likes: 7
Trumpy: The 'device' you see is actually one of many configirations that were readily available many years ago.
Common to see in old residential, they were used with 'zip cord' (2-wire lamp cord) to install receptacles along the baseboards. Some had screw terminals for connections, others had a piercing setup.
A basic source of fire potential, and most were a DIY install, although some of the 'old timers' may have installed it.
Mfg that I remember were 'Eagle' & 'Leviton'.
Harold must have seen this also.
I'm trying to make out how the mounting strap deal works on the baseboard outlet. I've never seen anything like that before! Monowatt, Gem, Academy, and Rodale made these things as well.. They seem to be common in turn of the century houses around here where there's maybe one outlet per room, fed by 16/2 zip stapled (and usually loaded with about 10 coats of paint) along the baseboard to another outlet.
Clearly a previous homeowner knew just enough to get himself in trouble.
Going down memory lane. The 'outlet' device had a backplate that was mounted to the surface (baseboard) with one or two flathead slotted wood screws.
They came off real easy witha claw hammer, and the many coats of paint flew all over the place.
There were some real interesting methods of tapping into the building wiring of the one real outlet. I remember quite a few bent device plates. The zip cord thru the walls was funny to, as the methods to get around a doorway.
Posts: 9,928 Likes: 34
That was what you expected to see in the 50s. I have seen those triple taps that screw to the wall and an assortment of other similar devices. I am not sure when the NEC started requiring minimum outlet spacing but one per room was very common in the post WWII housing boom so people were making up for it with these devices. Unfortunately they were typically run with 18ga zip cord but occasionally you saw "heavy duty" 16 ga cord. The only thing that saved us was the usual load was a lamp and maybe a radio or TV.
Harold must have seen this also. They still make and sell these. I have as large array of them for my Christmas display...
-Joe “then we'll glue em' then screw em'” -Tom Silva TOH
