That is an interesting question. A copper lug might react with the aluminum frame. Most aluminum lugs use a regular steel screw that does not hold up that well although that is what they use to bond screen cages near a pool. I ended up buying some 1/4-28 stainless set screws to put in the lugs I replaced the rusted ones with on mine.
