Here in NJ you have to take a ground clamp on the customer side of the gas pipe back to the grounding electrode of the electrical service. That means to me, you can connect to the #4 cu wire at the ground rod, or hit the inter-system grounding point of the electrical service. I believe there are a few more options, but these are the easiest to follow.
