cgw Offline OP
NEC 210.60(B) requires guards for receptacles athat are behind beds. This is pretty common for dorm rooms. does anyone make a "guard" that can be used in this case?
You should be able to find a t'stst guard at WW Grainger, McMaster Carr, or a good HVAC supply house.
cgw Offline OP
Sorry the title is incorrect. It should be receptacles (not thermostats).
OK. I have not seen any receptacle 'guards' in any of the hotels I have inspected.
A google search was unsuccessful.
If you're in a pinch....how about a 'bubble cover' (Weatherproof while in use) RACO used to make a real nice cast aluminum one.
Other suggestion would be to move/eliminate the receptacle.
Found this one on Google:
http://www.deltapoint.ca/index.php/industrial/dp6200-receptacle-guard
mbhydro:
That's a beautiful thing!!
Instead why don't you "locate them conveniently...." like 210.60(B) says
