by NORCAL - 03/19/24 05:11 PM
1 members (gfretwell), 32 guests, and 14 robots.
going through a practice question paper and theres a few questions I am struggling to find awnswers for in my notes, not sure which formula I need here but one of the questions is;
A self induced e.m.f. of 60 Volts is produced by a current of 6 amperes in 0.4 seconds. What is the inductance of the inductor?
any help much appreciated.
It's been a while but I think it is
V = L A/T so you have 60=L 6/.4 or 60=Lx15 or L=60/15 (4 henries)
Scott or one of the other engineers here can grade my work. wink
Thanks Greg that looks familiar, theres another question im unsure of if anyone can help;
a 15H coil (inductor) carries a current of 7A. What amount of energy is stored in the magnetic field?
Thanks again
Lee
welcome aboard from across the pond!
I think we need the voltage to figure that out.
It has been something like 48 years since I actually used this so I may be forgetting something.
Need to know the Frequency applied to this Inductor, to figure Xl.
(BTW: "pi" = Greek lower case "pi", or 3.141592653589...)
Formula is: XL = 2pi FL
If F= 60Hz, then XL =:
2 * 3.141592653589 * 60 * 15.0 = 5,654 Ohms
Find Voltage: E=IR
I = 7.0 Amps,
R = 5,654 Ohms
7.0 * 5,654 = 39,578 Volts.
Find Reactive Power: VAR= E * I
E = 39,578 Volts,
I = 7.0 Amps
VARs = 277,046 VARs.
--- Personal Note:
I think the value of the Inductor is quite large - 15H.
Substituting 0.0015H (15mH) for the Inductor results in a much more reasonable Reactive Component: 277.046 VARs, with a Potential Difference of 39.578 Volts (rounded to 40 Volts).
-- Scott (EE)
---let's see if these spec. characters work now!---
If you are looking for the energy stored in the magnetic field, I thought the formula was:
W = 1/2 x L x I^2
W = .5 x 15 x 49
W = 367.5 Watts
Larry
Link to where I found the equation:
Physics page
Larry
