pdh Offline OP
Anyone ever seen an IEC 60320 C13 outlet built as a wall receptacle, preferably for USA box and plate standards? Listed even better.
Just out of carosity, what are you trying to power? Plug configurations are to prevent applying the wrong voltage, improper ampere, and in this case, possibly the wrong frequency. By installing a receptacle of a certain configuration invites any type of equipment with that plug configuration be plugged into it. Even in an supervised environment. If you are installing a piece of European equipment that will work on the North American power grid, can't you just install the appropriate plug and recept configuration?
pdh Offline OP
Devices with C14 plugs are supposed to be able to handle 100-240 volts AC, 50 or 60 Hz. That's probably not the case for shavers and the like, but they have a different plug.
I also want the shroud configuration. I suppose Schuko might also work. Anyone ever seen those fitting American boxes? Or would I need to get the European box setup?
We had C13 panel mount receptacles in a lot of our machines. They are not a horrible fit in a L-15-R cover with the round hole but it is not listed to be used that way.
pdh Offline OP
I was figuring that if they were made for wall mounting, they would more likely be made to fit in a decora style plate, rather than the traditional ones. E.g. a single device with one, two, or maybe even three, C13 outlets, in the decora dimensions.
The problem with C13 is you are not sure what voltage will be there.
Just like the dual T slot.
Isn't nearly all equipment with an IEC C13 connector auto-ranging or equipped with a voltage switch?
What's the application, data center? I've seen a lot of power strips in rack-mount units that have IEC C13/15/19 outlets.
There are plenty of machines out there with switch selected or single voltage supplies
