The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
recall notice Cooper Lighting light reflector
by sparkyinak
Yesterday at 06:34 PM
450.3(C)
by Tesla
Yesterday at 04:07 PM
100AMP panel in 60 degree ambient what size wire?
by sidmuer
Yesterday at 09:25 AM
One Doorbell Button to 4 Doorbells/Chimes
by sparkyinak
05/21/12 11:37 PM
Housekeeping and Clean-up
by renosteinke
05/21/12 12:52 PM
An old Amprobe model 550
Shout Box
Top Posters (30 Days)
gfretwell 27
HotLine1 27
sparkyinak 18
twh 15
renosteinke 14
Classified Ads:
Electrical-Classifieds.com
Who's Online
2 registered (sparkyinak, OverZealous), 98 Guests and 2 Spiders online.
Page 2 of 2 < 1 2
Topic Options
Rate This Topic
#205458 - 02/22/12 04:31 PM Re: 250.64(F)(3)?? [Re: Up2code]
Up2code Offline
Loc: Missouri
Hotline, Lets use a basic, standard, big box store 200 amp breaker panel for example...
The equipment grounding conductor terminal bars are usually
1) Aluminimum
2) 1/4" thick, though with predrilled holes.
3) Minimum 2" long. Is that not the same as 2" wide?
I suppose this is where my confusion on this exact code section is coming from.
Top
#205460 - 02/22/12 04:56 PM Re: 250.64(F)(3)?? [Re: Up2code]
Niko Offline
Loc: Campbell, CA
Originally Posted By: Up2code
Niko, I have seen grounding bars that are 1/4" thick by 2" wide, in some bigger switch gear equip. So then that would not be a violation correct? I don't see the violation
But the grounding terminal bar that is not 1/4" thick by 2" wide, in similiar gear or subpanels, would obviously be a violation? Yes
Both those statements sound correct?
Unless some one can find an issue with the above but i don't see a problem with the 1/4" x 2" ground bar being in the panel.
_________________________
Top
#205467 - 02/23/12 07:31 AM Re: 250.64(F)(3)?? [Re: Up2code]
HotLine1 Offline
Loc: Brick, NJ USA
IMHO, we would be splitting hairs debating the 'big box' panel ground bars.
I see the wording within the NEC as a piece of copper, or aluminum that has three (3) dimensions; thickness, width, and an assumed length. Yes, the 'length' is not spelled out in any minimum dimension, but I consider it assumed.
There are formulas to determine amperage ratings for buss bars, and ground/neutral termination bars.
I think of this as attempting to terminate a GEC/EGC that is of a larger AWG than the max that the termination bar is designed to accept.
As Niko stated, I agree with the last scenario.
Top
#205468 - 02/23/12 11:21 AM Re: 250.64(F)(3)?? [Re: Up2code]
gfretwell Offline
Loc: Estero,Fl,usa
This is the picture in the handbook where they talk about this bus bar. It is clear they mean wide with the length unspecified (but assumed to be greater than 2")
BTW does anyone else question the green wire if this is supposed to be a picture of GECs? wink
Top
#205469 - 02/23/12 12:24 PM Re: 250.64(F)(3)?? [Re: Up2code]
Up2code Offline
Loc: Missouri
Thanks everyone for the input!
Gfretwell, IF the GEC grounding bar you have pictured,was installed IN and BONDED to a Feeder panel enclosure, would it be a violation?
Top
#205470 - 02/23/12 01:47 PM Re: 250.64(F)(3)?? [Re: Up2code]
HotLine1 Offline
Loc: Brick, NJ USA
Greg:
Thanks for the pic! I just took a few at a data center.
Yes, they have 750KCmil copper & it's green (Simpul)!!
Top
#205483 - 02/24/12 08:54 PM Re: 250.64(F)(3)?? [Re: Up2code]
mikethebull Offline
Loc: Rhode Island
I think this is refering to the bonding screw that comes with a panel. Some panel manufuterers give a piece of copper (copper clad) to bond the nuetral grouding to the enclosure this about .25 X 2 in. . And to Up2code if the main is outside the panel now is technically a subpanel in RI anyway.
Top
Page 2 of 2 < 1 2
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
