0 members (), 376 guests, and 7 robots.
#2043 06/16/01 05:42 PM
Hello
Does someon know how fluorence bolb works?
Thanks
#2044 06/16/01 11:09 PM
Mike, a simple explanation is; there is an anode and cathode inside a tube filled with neon gas. The tube is coated with a flourensce coating. The gas must be heated to glow and this is accomplished by fing a high voltage pulse into it. someone else may have a better explanation, if so feel free to jump in. Hope this helps.
#2045 06/19/01 04:56 PM
Anonymous
Unregistered
Since it is AC, there is no distinction between anode and cathode - the polarity reverses 120 per second.
#2046 06/19/01 07:48 PM
Light is produced by gaseous-conduction methods, when proper energy transistions result from electron displacement within the atomic structure of the gas involved.
Applied voltage at the electrodes accelerates free electrons from their normal atomic positions. Radiations of a particular wavelength result as the displaced electons return to their normal position in the atomic structure; this wavelength depends on the base used and the degree of electron displacement.
Once the discharge begins, the enclosed artc becomes a light source with one electrode acting as a cathode and the other as an anode. The electrodes will exchange functions as the supply changes polarity. This principal is employed in high-intensity discharge lamps.
source; AE Handbook, 10.114, 142
