1 members (ale348),
302
14
This is from a mechanical contractor's boiler room. If you're a control electrician, you get to do this kind of stuff.
LOL!!
I should have known better than to take a drink before clicking the link!
Guy was obviously a hack or he would've cut a CLEAN hole in the cover as opposed to cutting it from the side.......
Posts: 9,923 Likes: 32
Guess he didn't know about box extension rings.
We did have a thread here about using "device" boxes for relays.
Are they mixing line voltage with low voltage wires in that 4-11/16 box?
The low voltage wires are probably good for 120 volts but the open holes into the box are larger than allowed.
It looks like a lot of work to do something wrong. As Greg points out, there are extension boxes. I think an 8.8.4 box is a cost effective solution.
This is from a mechanical contractor's boiler room. If you're a control electrician, you get to do this kind of stuff. If you're a control electrician you'd learn how to do that sort of stuff properly.
thats scary!
i wouldnt even think of doing that in a million years!!!
poor selection of BASIC equipment, or in other words, `its what i found in the spares bin`
Oasis
we secure, others follow.
This is from a mechanical contractor's boiler room. If you're a control electrician, you get to do this kind of stuff. poor excuse for a RIB
And this is why I like our DIN Rail mounting stuff. Everything inside the one sealed box, no need to wack holes in everything.
