The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
recall notice Cooper Lighting light reflector
by sparkyinak
Yesterday at 06:34 PM
450.3(C)
by Tesla
Yesterday at 04:07 PM
100AMP panel in 60 degree ambient what size wire?
by sidmuer
Yesterday at 09:25 AM
One Doorbell Button to 4 Doorbells/Chimes
by sparkyinak
05/21/12 11:37 PM
Housekeeping and Clean-up
by renosteinke
05/21/12 12:52 PM
An old Amprobe model 550
Shout Box
Top Posters (30 Days)
gfretwell 27
HotLine1 27
sparkyinak 18
twh 15
renosteinke 14
Classified Ads:
Electrical-Classifieds.com
Who's Online
0 registered (), 96 Guests and 1 Spider online.
Page 1 of 2 1 2 >
Topic Options
Rate This Topic
#204119 - 11/14/11 10:52 AM Article 511 Required sealing
Yoopersup Offline
Loc: Michigan
511.9
If a conduit does Not pass thur a Classified
area sealing is Not required.
See page 771 Exhibit 511.1.
If a conduit comes from Outside the building goes up to 28inches then enters a box inside a poured concrete wall it never enters the classified area. Thus Seal not required.
Whatca think??
Same as example on page 771 but conduit comes from outside & stays inside the outer wall.
Yoopers
Top
#204121 - 11/14/11 01:09 PM Re: Article 511 Required sealing [Re: Yoopersup]
HotLine1 Offline
Loc: Brick, NJ USA
IMHO, you are correct, no seal required.
_________________________
Top
#204189 - 11/18/11 09:10 PM Re: Article 511 Required sealing [Re: Yoopersup]
HotLine1 Offline
Loc: Brick, NJ USA
Done???
Top
#204201 - 11/19/11 12:01 PM Re: Article 511 Required sealing [Re: Yoopersup]
gfretwell Offline
Loc: Estero,Fl,usa
It sounded pretty done to me but you probably still need some duct seal to prevent the cold air, condensation thing. That is not a real seal off tho.
Top
#204208 - 11/20/11 01:55 PM Re: Article 511 Required sealing [Re: Yoopersup]
Yoopersup Offline
Loc: Michigan
Thanks guys it just what I figured ,
Top
#204226 - 11/21/11 04:11 PM Re: Article 511 Required sealing [Re: Yoopersup]
Yoopersup Offline
Loc: Michigan
Just got written up by Local Inspector for doing it.
Guess 90.4 comes into play!
Yoopersup
Top
#204227 - 11/21/11 04:46 PM Re: Article 511 Required sealing [Re: Yoopersup]
gfretwell Offline
Loc: Estero,Fl,usa
It all gets down to what is "inside". (which side of the wall is the border).
I can put my "flush mounted jelly jar" hat on and see his point. We call the outside wall the border there and let them use Romex to a dry location octagon box.
He must be saying the conduit is traveling through the classified location, inside the wall.
Top
#204230 - 11/21/11 07:37 PM Re: Article 511 Required sealing [Re: Yoopersup]
HotLine1 Offline
Loc: Brick, NJ USA
I take Yoops job from the OP as the box and conduit being encased in a poured concrete wall. I can't see how that can be 'in' the classified area, also with the dimensions he posted.
On that thought, unprotected service conductors encased in 2" of concrete are 'outside the structure'. Although Yoop did not provide wall thickness dimensions, or a conduit size. it sounds like it could be 2"+ encased in poured concrete.
Top
#204235 - 11/22/11 07:52 AM Re: Article 511 Required sealing [Re: Yoopersup]
Yoopersup Offline
Loc: Michigan
Right he says even thought its in 2 inches Concrete coming from outside its in classified area. I disagree. \
Conduit comes below ground up Outside poured wall to Panel.
I know this area was revised in 2005 but I didn;t find that deleted??
Yoopersup
Top
#204241 - 11/22/11 02:16 PM Re: Article 511 Required sealing [Re: Yoopersup]
Yoopersup Offline
Loc: Michigan
Edited by electure (11/22/11 09:23 PM)
Edit Reason: to add image from Photo Gallery
Top
Page 1 of 2 1 2 >
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
