Sparkync,
I hear you about the "Supply Houses" anymore. Times are tight and the supply houses become "order houses", because they may not have what you need right now, but they will be happy to order it for you. Problem here is that it might take a month to get the part, cause they only order once a month from a distributor. Unless you want to pay the "overnight" freight fees.
