Ahhh, Trainwire has brought up an area which I have some Qs about! I hope you don't mind me tossing Railroad related questions out.
(some parts relate to Generators and UPS / back-up power systems).
If this turns into an "Attempted Thread Jack" situation, I'll begin a new thread (or resort to direct E-mail contact).
Anyhow, on to the subjects!
I am currently installing two brand new 25KW 240volt 3 phase desiel
generators in our train. We use them to power the kitchen in the dining
car,and the parlor car.
Are you installing the Genny(s) in a Locomotive? Maybe in place of an original Steam Generator? (or is this a new HEP setup?).
If yes, what type of Loco is receiving the HEP package?
Does the RR you work for have any Locos with HEP packages?
Do you have experience/knowledge of units with HEP?
I am not too familiar with ALCO Diesel / Electric equipment - more an EMD and GE "Based" person! (all the major carriers in my area use EMD and GE primarily, only a handful of ALCOs dawn the motive power databases, they are normally hidden in yards - like for Hump Operations or Classification).
What's your take on the GE "Genesis" series Dash 8 units with HEP packages?
More precisely, P40 Dash 8 (dash 8 408) and P42 units.
What is the rating of the Stand-Alone HEP Genny / Prime Mover? These were the first units I experienced with a separate HEP prime mover! I was stunned when the Loco(s) stopped at a station and the main Prime Mover idled down while the cars had steady AC Power!
I was "Raised" on the EMD F40 PH, so prior to the Dash 8 experience, I had only dealt with HEP coupled to the Main Prime Mover - hence no idle down at stations / other stops (Main Prime Mover ran at steady 720 or 900 RPMs. For those thinking this is slow, this is high end RPMs for that Diesel Motor! Since it's a 2 stroke 16 cylinder beast, 900 RPMs sounds like 9,000 RPMs!!!).
Any experiences with EMD's newer units (F59 PHI to be exact). This Animal also uses a separate HEP package, plus the Main Prime Mover is a 4 stroker. Traction Motors are still DC type - and driven with DC (apparently for Passenger Duty reasons).
Outside the Drawbar Zone
, I would like to get information regarding the Signal Department's stuff!
Out here, the major carriers have just about converted all Main line Subdivisions to CTC.
BNSF finally changed over the last remaining section where Santa Fe's "Rule 251" was used on a large portion of Double Track with Sidings. Trains that were overtaken went into the hole manually!
The Blocks were part ABS and TWC, and traffic ran one direction on a given track (no crossovers, like found in CTC territory!).
This is an interesting subject, so let me know if I should explain more detailed.
At Relay "houses" for Signals and Street Crossings, the power system was roughly a 120 VDC system - driven by an array of Series Connected Liquid Acid Batteries, and charged by a 5 KVA Stepdown Transformer.
Not sure if this continues here. Any ideas where I could find information about this?
Nearly all Districts use AFO for Street Crossing control / traffic sensing. Looking for detailed info on not only AFO, but control techniques per signal equipment.
Have noticed a few older Branch lines with jointed rail (as opposed to CWR), use a system that does not act like AFO!
It appears to be tripped into action, then tripped out.
Gates come down a good 2 minutes before traffic occupies the street crossing, then remain down long after the last car has cleared.
It's like they are set for 90 MPH @ 30 Seconds! The Max Speed on these Branches is 10 MPH, so street traffic piles up big time!!!
Not to mention when some clown cuts a rail joint jumper - thus setting the signals into error status (gates down for days!), the traffic really collects!
P.S. Abbreviations mean:
"AFO" = Audio Frequency Overlay,
"HEP" = Head-End Power,
"CTC" = Centralized Traffic Control,
"CWR" = Continuous Welded Rail
So many Qs', such little time!
Scott s.e.t.
