390
14
Do most of you bend the bx and use tin snips to cut it or use bx cutter or hacksaw method?
Posts: 2,236 Likes: 1
No contest... BX cutter, "can opener" type...
Posts: 4,116 Likes: 4
'66 I'll second you (except for larger sizes which need Hacksaw) Bill
I take my Klein diagonals and pinch a rib with the very ends of the cutters. Then you just "unscrew" the aluminum about a 1/4 turn and pull it off. Quick, easy and you don't need to carry around an extra tool.
I had a Roto-Split just sitting in my box for years, until one day my Klein BX cutters broke. After I used the R-S for the rest of the day, I realized how much easier & faster it works for me. Never went back.
Originally posted by Fred: I take my Klein diagonals and pinch a rib with the very ends of the cutters. Then you just "unscrew" the aluminum about a 1/4 turn and pull it off. Quick, easy and you don't need to carry around an extra tool. I have been using a Roto-Flex for years but I will certainly try this method
