Admin 19
Anyone hiring inspectors?
by HotLine1. 03/26/17 06:12 PM
Old decora style outlets
by Admin. 03/25/17 11:40 AM
ESA Arc flash course
by TheShockDoctors. 03/24/17 10:15 AM
fuse rejectors
by HotLine1. 03/24/17 07:53 AM
Another Forum Update
by Admin. 03/22/17 03:04 PM
SE cable question
231,537 Are you busy
166,260 Re: Forum
160,670 Need opinion
0 registered members (), 54 guests, and 12 spiders.
Rate This Thread
#203368 - 09/25/11 12:37 PM Lots of Space?
Admin  Offline
NY, USA
Walking distance from my house. There is a lot of land around. I don't understand why...
Electrician7
2017 / 2014 NEC & Related Books and Study Guides
#203373 - 09/25/11 03:00 PM Re: Lots of Space? [Re: Admin]
mbhydro  Offline
Winnipeg MB Canada
I am going to guess that the left side module on the DSLAM was an add on after the initial instal.
Otherwise the splicers would never have been able to open the distribution box to make the initial connections to the underground lines.
To move either one would take time and money to splice and I hear in the US some telco's don't want to spend either on copper lines.
#203374 - 09/25/11 04:06 PM Re: Lots of Space? [Re: Admin]
Electrician7  Offline
Alberta, Edmonton
mbhydro,
It's Canada. I am not sure about details. Just a fact.
#203390 - 09/26/11 06:57 PM Re: Lots of Space? [Re: Admin]
mikesh  Offline
Victoria, BC, Canada
Maybe the small box is replaced by the big one? they are both telco.
#203419 - 09/28/11 11:56 AM Re: Lots of Space? [Re: Admin]
EV607797  Offline
Fredericksburg, VA, USA
Pedestals with louvered doors are almost exclusively used for CATV. This is because all of their gear is designed for outdoor (aerial use). Louvered doors aren't used for telco splices because of the potential for moisture.
Don't forget that this pedestal is double-sided, so it is possible that everything in there is completely accessible from the other side.
Then again if it is CATV, since when do they and the telcos get along, especially now that they are in competition with each other?
---Ed---
#203647 - 10/17/11 09:41 AM Re: Lots of Space? [Re: Admin]
harold endean  Offline
Boonton, NJ
You might need the skinniest service man to work on that box.
smile
#203803 - 10/25/11 08:39 AM Re: Lots of Space? [Re: Admin]
techie  Offline
palo alto, ca usa
It does not appear to me that the pedestal is double sided. There may be a removable panel on the other side, but the doors open (or not) towards the blocked side.
Alan Belson
Alan Belson
Mayenne N. France
Show All Member Profiles
2017 NEC and Related
2017 NEC
Now Available!
Shout Box
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.020s Queries: 15 (0.004s) Memory: 0.7839 MB (Peak: 0.9386 MB) Zlib enabled. Server Time: 2017-03-27 02:55:42 UTC
