205
30
Stranded wires under the device terminals. I know it is not an NEC requirements but i need help finding the answer if it is allowed or not. I looked in my UL 2010 white book but i wasn't able to find anything.
Is it a manufacturer instruction that stranded wires can not be installed on the devices or UL requirement?
Thanks.
Posts: 9,928 Likes: 34
Standard devices are listed for stranded or solid wire. From the White book RTRT Terminals of the wire-binding screw, setscrew, or screw-actuated back wired clamping types are suitable for use with both solid and stranded building wires.
Unless the instructions state otherwise right?
I am not sure how the instructions can defy the listing standard and still call themselves listed. Do you have an example?
I know the back stabs are solid only but this refers to the various styles of screw terminal
From Pass & Seymour:
Side wire accepts #12 – #14 AWG solid wire.
For trade master TR receptacle 3232
With stranded wire, I always use the pressure plate type receptacles, or put spade lug crimps onto the conductors for use with the standard screws.
According to the UL white book
Receptacles are listed to use stranded wire as long as it is terminated by one of the following: wire-binding screw, setscrew,or screw actuated back wired clamp type terminal
Switches are not listed to use stranded wire.
Spade lug or fork crimp terminals on the stranded wire is not a listed method for terminating the conductor to the device.
Does the stranding have to be the standard 19 strand or could it be the extra fine stranding with a strand count of 39 or 51 strands?
Table 8 specifies the stranding and that fine stranded wire is not it. You really get into this when guys stuff it in a regular set screw lug. You need the kind with a shaped washer on the set screw to catch all the strands and compress them in the lug.
Standard devices are listed for stranded or solid wire. From the White book RTRT Terminals of the wire-binding screw, setscrew, or screw-actuated back wired clamping types are suitable for use with both solid and stranded building wires. I agree, but if the manufacturer states solid only then you have to follow instructions that come with the product. Right?
