1 members (Scott35), 361 guests, and 11 robots.
Niko #201311 05/27/11 01:45 PM
Niko:
You said a 'small computer room'?
Is that room a 'IT' classified room? (Article 645)
I suggest that you check into that Article. As you said a 'small start-up' company, but your building dept may have issues with that 'room'.
It all depnds on what it is 'called' and by whom.
A seperate system works in an 'IT' room by Art 645, but there qre other requirements.
Niko #201313 05/27/11 03:53 PM
Use a wall mounted air conditioner -- say one-ton...
And have the condenser vent heat into some other space.
Just cut in a hole in the sheet rock and reframe it to hold the unit.
The last time I looked such units did not use a momentary switch.
A truly portable air conditioner works for people -- not machines.
You need to get the heat entirely out of the IT room.
Tesla
Niko #201314 05/27/11 05:58 PM
I doubt very seriously that this would qualify as a 645 room.
Just because you put a computer in a room does not make it a "computer room". wink (645.4)
I doubt a mini split is going to do much for him either. They usually only have a wireless remote for the controls and the two I have come back from a power failure "off".
If I was really going to hack this, I would come up with a N/C point of a relay to provide the "on" pulse and pick the relay with a voltage generated inside the AC unit. That is how I kick started the MP3 player PCs in my cars that had ATX power supplies.
You still may want to do this in conjunction with an HVAC contractor for a little legal cover.
Niko #201324 05/28/11 04:09 AM
BTW one consideration is starting the compressor into a hydraulic lock. If you have an auto restart you should have a lock out time delay relay on the compressor so it won't short cycle if the power glitches. Those reclosers usually cycle faster than you would want to stop and start a compressor.
Niko #201329 05/28/11 04:17 PM
K
Liebert is a big name in data center cooling. They are not cheap, but if it's in the budget, I would probably look into one of their small data room cooling systems.
Liebert
