Greg,
They use to work with all sorts of wacky voltage and freq. in their factory. They even had one system that was 400 Mz I believe. It was for satellites or something.
I suspect that would be 400hz, which is very common in aerospace. I believe that it became a standard from about 1940s onwards, because it was the most efficient for weight/iron loss in transformers, long before power conversion electronics became available.
However, I've heard of 400hz gear in military naval roles, where weight presumably isn't an issue. I've wondered why.
The systems I worked with were always 200v 3 phase/115v to ground.
