403
11
Posts: 7,381 Likes: 7
Found this responding to a tenant complaint in building. Fire Prevention followed me, they wrote nine (9) violations. Interesting that a building that has done no electrical work...has yellow #12 NM
I like it now that romex has a date of manufacture on it now also
handymen don't actually do any "work"
looks mighty familiar HotOne
but how do we know that the new RX was simply a service call to replace a bad wire by a bona fide sparky there?
~S~
~s~: Based on what I saw...the last 'bonafide sparky' there was the crew that wired the structure way back when!
As is often the case Hotone
that said, other than working clearance, and a missing panel cover, can you tell us what violations were found?
~S~
~s~: Synopsis of issues: Missing/broken smoke & heat detectors. Defective fire extinguisher. The obvious panel clearance & open wiring Missing covers on various j-boxes Housekeeping issues; trash, waste debris Inproper Flamable storage. Blocked egress Damaged sheetrock (wall/ceiling)
Doug: Just an FYI, I couldn't get close enough to the open panel to look for the date stamp. Yes, that's handy to have a 'date'.
point taken
i sign & date all my installs
i also collect old code books, due to the term existing being predicated on a compliant install at the time
~S~
~s~: I also have a collection of NECs, they sure come in handy on some 'old' jobs.
