#199703 03/05/11 05:50 AM
pooL8 Offline OP
What would you do if a residential customer wanted an new 120V dedicated circuit but panel is full?..... of tandems.
Pretend they don't want any added/upgraded panels.
Walk away.... fast!!!
Jimmy
twh Offline
Can you pull two circuits out of the panel and combine them into one circuit?
Subpanel ??? This is always a problem in older houses with a kitchen reno.
things like mircrowave hood combos dish washers that were hacked into the laundry plug in the basement, fridge relocate new counters that need more counter plugs now etc.
pooL8 Offline OP
laugh ... Ya...
If you stay reallllly still, they might forget...
then you can steal all their cookies!
pooL8 Offline OP
You can...
This isn't a real situation for me... just gettin some input.
It's a good idea, load permitting ofcourse.
twh Offline
Oh, its a hypothetical question. Run an extension cord to the neighbor's separate circuit outside plug. No one ever tripped over a hypothetical extension cord.
Actually, this problem comes up a lot. It's the reason the DIY stores sell SJ cord by the foot.
pooL8 Offline OP
smile
Ya it does come up a lot.
Can't really win either way... I mean it can be safe, especially if you fed the 2 circuits with a #12 (or #10 if it's an FP panel)
But running away is a little nicer for the pains.
Though I still raise an eyebrow when I dedicate a dining room plug. I can't remember anyone using it for something other than a lamp or phone, if anything.
I would say you can't answer this question without a load calculation.
twh Offline
Greg, in Canada we can put 12 outlets on a 15 amp circuit. When a panel is full, sometimes it's because every electrician ran a new feed for every new outlet. Then, we can pull two circuits out and combine them on one 15 amp breaker.
The dining room plug is outdated. I haven't seen a toaster on a dining room table for 30 years.
