Sophisticated test equipment, calibrated properly, can detect the minute differences in length of each pair, caused by their differing twist rates. If you have a switch or rack set up for 568B and you terminate by the A color code on a B jack, even if you do both ends the same, the cable should fail. Not all test equipment produces this result. You get what you pay for.
