See the problem with hitting an E-stop on a palletising robot with boxes on it's pick-up head is not that it stops the robot and the in-feed lines.
It is the fact that when the robot re-starts, it "forgets" it has the boxes on it's pick-up head and attempts to pick up more boxes.
This is actually pretty scary to witness, although I've found a work-around to this problem.
More training from the technician that installed this gear would have been good although it seems that he wants to keep a certain amount of information close to his chest.
What makes it even harder is the fact that he is based at the other end of the country, which is really handy, should this gear really throw a wobbly, as it has done in the past.
I have to be honest and say that the only thing that has saved this robot system from serious damage is the fact that any configuration/positioning settings are password protected and only myself and the technician have that password.
Having said that, while I'm pretty much up to speed with robotic positioning systems, changing settings like this is IMO rather worrying, this thing moves at 5m (15ft) per second, you couldn't hit the E-stop quick enough if it was headed for one of the walls, the ceiling or the security fence.
At least I'm being paid good money to sort all of this out, if the money wasn't there, neither would I be.
