1 members (Scott35), 200 guests, and 25 robots.
#195989 09/03/10 10:26 AM
Bravo Offline OP
Hello,
I am designing power for an exterior heated enclosure for domestic water piping.
the pwr source will be from stand-by generator circuit.
does the heater have to be supervised?
if so, from where? Fire alarm and/or building management interface panel?
thanks in advance.
Dean
An overall picture of why you are heating the system would help any replies.
And welcome to ECN.
Shane
Bravo Offline OP
to keep the pipes from freezing. It is a aluminum enclsosure (HB8E-D) with dual 1900W heating elements. The circuit is fed from stand-by generator distribution.
not to be pointed in right direction for nfpa supervisory ckts.
thanks
Dbravo:
Welcome to ECN forums.
Additional information on the project is required;
Why are heaters required, other than freezing? What type/use group of structure/building?
Is the gen a legally required system, or is it an optional system?
Supervisory circuit to bldg mgt sounds like a good move. The FACP? Perhaps, if the water is destined for fire supression use.
More info will get you more answers and opinions.
