The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
450.3(C)
by Tesla
05/23/12 04:07 PM
100AMP panel in 60 degree ambient what size wire?
by sidmuer
05/23/12 09:25 AM
One Doorbell Button to 4 Doorbells/Chimes
by sparkyinak
05/21/12 11:37 PM
Housekeeping and Clean-up
by renosteinke
05/21/12 12:52 PM
Back to back bends on electric bender
by Tesla
05/20/12 05:38 PM
An old Amprobe model 550
Shout Box
Top Posters (30 Days)
gfretwell 27
HotLine1 27
sparkyinak 17
twh 15
renosteinke 14
Classified Ads:
Electrical-Classifieds.com
Who's Online
2 registered (twh, acastillo), 110 Guests and 2 Spiders online.
Page 1 of 2 1 2 >
Topic Options
Rate This Topic
#194608 - 06/13/10 07:27 PM 3-ways in stairs
romex2121 Offline
Loc: nm
per the 2008 NEC how many steps need to be present to justify a 3-way system,,, example 2, 4, 6,
Top
#194611 - 06/13/10 08:23 PM Re: 3-ways in stairs [Re: romex2121]
HotLine1 Offline
Loc: Brick, NJ USA
210.70 (a)(2)(c) provides the answer...
"(c) Where one or more lighting outlet(s) are installed for interior stairways, there shall be a wall switch at each floor level, and landing level that includes an entryway, to control the lighting outlet(s) where the stairway between floor levels has six risers or more. "
_________________________
Top
#194805 - 06/23/10 02:15 AM Re: 3-ways in stairs [Re: HotLine1]
sparkyinak Offline
Loc: Alaska
your local building code may have more to say on the switching requirements
"Good judgment comes from experience. Experience comes from bad judgment."
Top
#195137 - 07/13/10 02:08 AM Re: 3-ways in stairs [Re: sparkyinak]
Trumpy Offline
Loc: SI,New Zealand
A lot of what I am seeing these days is not actual switches, but PIR switching on stairwells.
Where as a given flight of stairs might have a sensor on it, it will trigger on movement at the bottom of the stairs and also trigger a delay timer at the top of that set of stairs, that energises the next PIR (and lights) and turns off the lower lighting.
If it saves lights being left on all night,, I'm all for it.
Having said that, in fire situations, it's all lights on.
Let's face it, these days if you're not young, you're old - Red Green grin
Top
#195150 - 07/13/10 11:33 AM Re: 3-ways in stairs [Re: Trumpy]
gfretwell Online   content
Loc: Estero,Fl,usa
I like motion lights. The light follows you around my house, inside and out.
Top
#195425 - 08/02/10 02:06 PM Re: 3-ways in stairs [Re: gfretwell]
Alan Belson Online   content
Loc: Mayenne N. France
My wife follows me round the house switching them off, which is nearly the same but with added mutterings about utility bills laugh ! Seriously, you could lose all the cost saving advantages of low-energy lights if the switch timers are of too short a duration. They don't like short runs.
Wood work but won't!
Top
#195427 - 08/02/10 03:46 PM Re: 3-ways in stairs [Re: Alan Belson]
Loc: Estero,Fl,usa
I thought that was true but I have CFLs in the motion lights in my garage, the post light out front and one of the lights inside. They seem to be holding up OK.
Top
#200306 - 03/28/11 07:33 AM Re: 3-ways in stairs [Re: romex2121]
harold endean Offline
Loc: Boonton, NJ
Do you really need a 3 way switch at the top and bottom of the stairs when the stairway goes into an attic? smile
Top
#200308 - 03/28/11 07:58 AM Re: 3-ways in stairs [Re: romex2121]
HotLine1 Offline
Loc: Brick, NJ USA
Harold:
It will depend on the definition/use of the 'attic'.
Pull down stairs for access to the space I would say only a switch at the entry, walk-up stairs to a space that could be 'occupied' may require a 3-way. Intent and design fall into the discussion at that point.
Top
#203286 - 09/18/11 09:02 PM Re: 3-ways in stairs [Re: romex2121]
mikethebull Offline
Loc: Rhode Island
PIR switches are nice but they have to have regular switching. So as not to leave anyone in darkness.
Top
#204898 - 01/19/12 04:31 PM Re: 3-ways in stairs [Re: romex2121]
Trick440 Offline
Loc: Waterford, MI, USA
3 steps in Michigan...
http://www.RhinoElectrical.com
Top
#204903 - 01/19/12 09:05 PM Re: 3-ways in stairs [Re: romex2121]
sparkyinak Offline
Loc: Alaska
IRC requires switches even if a PIR is used. Because they can and do fail
Top
#204904 - 01/19/12 09:41 PM Re: 3-ways in stairs [Re: sparkyinak]
Loc: Estero,Fl,usa
That is the code run amok.
I suppose someone should point out, switches break and lamps burn out too.
Top
#205703 - 03/23/12 12:54 AM Re: 3-ways in stairs [Re: romex2121]
pdh Offline
Multi bulb lamps, extra lamps, multiple motion detectors, and a bank of switches. Oh wait, also an emergency break-in box with a flashlight, and extra batteries. That should cover lots of breakage :-)
Do they have a wattage requirement, or can I use 4 watt bulb.
What about permanent step lights? Can I get by with just those?
I didn't see where it said 3-way. Can I use on/off contactors?
Top
Page 1 of 2 1 2 >
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
