1 members (Scott35), 536 guests, and 17 robots.
Y
Does this section cover both High & low resistance grounding in this voltage bracket. I take it it does.
Yoopersup
F
IIRC yes it do but I did not get a chance to read the most recent change on that part so if it was unchanged from 2005 then it is correct.
Merci,Marc
Y
Was 480 to 1000 volts not 100 volts oops!
Yoopersup
