The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
Looking for a unique adjustment nut
by HotLine1
Today at 07:14 AM
A taper or B taper, which is it?
by JoeTestingEngr
Today at 12:39 AM
GE low-voltage remote control relay system
by Albert
Yesterday at 10:26 PM
Electrical systems in mobile structures.
by gfretwell
Yesterday at 09:21 PM
Conduit Bending Apps for iPhone -Master Bender
by KJay
Yesterday at 08:31 PM
A What's right here??
Shout Box
Top Posters (30 Days)
gfretwell 72
HotLine1 68
KJay 34
sparky 28
renosteinke 26
Classified Ads:
Electrical-Classifieds.com
Who's Online
1 registered (Albert), 126 Guests and 3 Spiders online.
Page 1 of 2 1 2 >
Topic Options
Rate This Topic
#193207 - 03/21/10 11:18 AM Is the GEC covered by 300.5?
gfretwell Offline
Loc: Estero,Fl,usa
There is a vociferous debate going on in the Fl IAEI BB about this.
It is currently a tie. Some say the table rules, the GEC is a "conductor" and if it is buried between the electrodes or from the electrode to the building it has to be covered per 300.5 table. Others say article (text) 300.5 only applies to "cables and raceways".
NFPA has rejected several proposals to specifically expand the language to include the GEC so the intent seems to be that this is not what they think it says. The other side says they rejected the proposal because it would be redundant.
Why keep a fun fight like this in Florida? What say ye? wink
_________________________
Top
#193214 - 03/21/10 03:18 PM Re: Is the GEC covered by 300.5? [Re: gfretwell]
George Little Offline
Loc: Michigan USA
Okay Greg, my vote is for table 300.5 to be followed because Column 1 covers Cables or "Conductors" and I think I heard you say "Grounding Electrode Conductor"
George Little
Top
#193215 - 03/21/10 04:38 PM Re: Is the GEC covered by 300.5? [Re: George Little]
gfretwell Offline
Loc: Estero,Fl,usa
Just being devil's advocate, you can't use a table until the text directs you there and article 300.5 says table 300.5 applies to "cables, conduits and other raceways". Without that text guidance you could easily mis-apply a table.
Top
#193216 - 03/21/10 04:46 PM Re: Is the GEC covered by 300.5? [Re: gfretwell]
gfretwell Offline
Loc: Estero,Fl,usa
The second question is that since you would have to excavate down 24" to connect the EGC would you need to drive an 8' rod down from that point or use a 10' rod? 250.53(G) does say the rod has to be "driven" into the soil, not buried, unless soil conditions prevent driving a rod.
Top
#193217 - 03/21/10 05:13 PM Re: Is the GEC covered by 300.5? [Re: gfretwell]
Loc: Michigan USA
Okay, I change my answer. The GEC becomes somewhat like the bonding wire used around a swimming pool. No depth dimension is given unless the wire itself is the equipotential grid.
See how flexible I can be?
George Little
Top
#193220 - 03/21/10 07:49 PM Re: Is the GEC covered by 300.5? [Re: George Little]
HotLine1 Offline
Loc: Brick, NJ USA
I have to say that I never gave this a thought.....until now!
Top
#193225 - 03/22/10 08:18 AM Re: Is the GEC covered by 300.5? [Re: gfretwell]
Rewire Offline
Loc: Missouri
the code does not address at what point on the ground rod you make your connection you could make your connection two feet down on the rod
Top
#193226 - 03/22/10 08:26 AM Re: Is the GEC covered by 300.5? [Re: HotLine1]
harold endean Offline
Loc: Boonton, NJ
The easy answer to this is, who cares! However that it not a professional answer. Low voltage cable can be buried 6" down as per table 300.5. So can't a conductor that doesn't have current (in normal conditions) be allowed to be buried 6"? As long as it is not laying on the ground where it could trip people or be damaged by power equipment. Right?
Top
#193231 - 03/22/10 11:04 AM Re: Is the GEC covered by 300.5? [Re: harold endean]
gfretwell Offline
Loc: Estero,Fl,usa
I am in Harold's camp on this one. It is a low voltage wire and 6" is plenty, particularly since this is usually right up against the building but there are several people over at Fl IAEI who want 24". When I asked about the driven rod (undisturbed soil) question they pointed out you can bring a conductor up to grade for the termination but since the whole run could only be 6' long, with a 45 degree slope on the rise, you would really only have 33% of this wire at depth.
Since our footings are also only 12" below grade, the structural inspector might have an opinion about digging a trench a foot below the footing, right next to it. If it was open for a few days of rain in the inspection process that footing might end up being "a bridge over troubled water".
Top
#193232 - 03/22/10 11:07 AM Re: Is the GEC covered by 300.5? [Re: harold endean]
Alan Nadon Offline
Loc: Elkhart, IN. USA
Discussed this for all of two minutes years ago. As long as it is protected from damage, depth makes no difference.
While waiting for the phone to ring consider this, is the wire between ground rods a Grounding conductor or a Bonding conductor ?
Seems that the Code people made a big deal about telling them apart.
Alan--
Top
Page 1 of 2 1 2 >
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
